Trailer Wiring Harness Problems
You can skip to the point at the *** below. Read on for the back-story.
I don't usually tow with my rig, just once every few years or so, but last time I did I had an unpleasant surprise. A few blocks from the U-haul rental place and a few minutes after they closed, my turn signals, hazard lights, and horn went out. I pulled into an auto parts store for some fresh fuses and replaced the blown one. The new one burned out a few minutes later, unsurprisingly.
It was late December, the weather was nasty, and I had a vanishingly small window of time use the trailer so I dropped it off in front of the rental yard and started waiting for Spring. My fuses kept blowing until I cut out the 3-2 converter for the trailer wiring harness, so I figure there was a short in the converter.
Fast forward to present. I'm going to try the move again this weekend. I replaced the 3-2 converter today and discovered a bit of a mess while I was at it. Don't ask me why I hadn't noticed, fixed this years ago.
The original trailer wiring harness was installed years ago by Spillar Custom Hitches in Austin, TX. It seems they spliced into the trucks wiring harness with quick-splice clips just in front of the back bumper on the driver's side (and one on the passenger side for the rt. turn signal). From the nicks in the wires' insulation near the quick-splice clips, it looks like they got the splices right on the second or third try.
I'm surprised I haven't snagged the whole mess on a low branch or some other
grabby on a trail.
*** The Point ***
Problem: The wires leading to my tail lights are exposed (out of the bundle sheath) where the quick-splice clips T in the trailer harness and the insulation on the truck's harness is nicked in several places.
Solution (short-term): I just spliced in a new 3-2 converter for the trailer using the existing quick-splice clips. It'll do for now.
Solution (long-term): I figure I should move the splices and the 3-2 converter to a more protected location (like behind a tail light). The I'll want to repair the insulation on the truck's harness where the quick-splice clips were. Any thoughts on how I should do that? Heat-shrink tape? Silicone caulk? Both?
grabby on a trail.
*** The Point ***
Is there a better way?
there might be if you look there might be a plug that this harness plugs into.
Without looking it is hard to tell as I don`t remember.
What i did on my 4Runner was use the plugs that the tail light plugs into and made my own adapter then only had to bring in the wire for the right turn signal. that way all the connections are behind the tail light.
Just use the new adheasive heat shrink tubing. It has an aheasive sealant inside and when it shrinks it glues and creates a water tight seal. It's a little more expensive but the stuff is great.
steve miller
Oct 10, 2015 01:40 AM
