General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Taping SW Power
Old Jan 20, 2012 | 09:41 AM
abalagtas's Avatar
Taping SW Power
I'm installing a new radio and cleaning up the wiring.
I'm using the 'switched power' lead from the radio wiring harnes. Can I tap this wire for my CB SW Power and my LCD monintor too?
Old Jan 22, 2012 | 12:24 PM
93NMyota's Avatar
on which vehicle? the scion or 4runner? also what kind of cb? some have a higher current draw than others, the lcd screen shoulnt need much so i say that one will be safe to tap the switched power on either vehicle.
Old Jan 23, 2012 | 11:49 PM
abalagtas's Avatar
it's for the 4runner. The CB is from Radio Shack I don't remember the model#.
Old Jan 24, 2012 | 06:56 AM
93NMyota's Avatar
Ok well i went to radio shacks site and saw that it would only require 1.5amps (radio shack brand unit) you should be fine with the switched power at the radio. BTW the switched power wire at the radio is GRAY and is protected by a 7.5amp fuse and is labeled "RADIO" at the drivers side kick panel if you run into any issues
chukarhunt
Dec 8, 2019 11:39 AM
theking11863
Mar 19, 2016 09:36 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
bighaydn
Aug 4, 2015 07:17 PM
defrag4
Jul 31, 2015 10:50 AM
