General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Signal Lights not working
Old Dec 27, 2005 | 09:10 AM
mandolaire's Avatar
My signal lights stopped working....when you click down, nothing. Interesting enough, the flashers work. I have checked all the lights and they appear to be working.
Suggestions? Thanks.
This truck is new to me...and I am bleeding; I have replaced Brakes, Timing Belt, Belts, Water Pump, all the fluids, and repaired a couple of big rust holes...and now this...
Old Dec 27, 2005 | 10:01 AM
Nic's Avatar
Nic
May be a simple fix. Have you tried replacing the bulbs? You might want to get a new bulb (if you haven't already) and try one side at a time. I have had similar problems, only finding out later it was just a bulb.
Old Dec 27, 2005 | 10:23 AM
dibble9012's Avatar
what truck is it/generation?
on my 3rd gen 4runner if a bulb is out, the blinkers flash rapidly, also, if the emer. flash button is not connected correctly, they will not work at all.
do the arrows light up on the dashboard?, do you hear the relay clicking?
Old Dec 27, 2005 | 01:08 PM
Elton's Avatar
check the fuses
Old Dec 27, 2005 | 06:38 PM
blown4runner96's Avatar
these are all possible scenerios... your hazards work off a different switch. Check your switch, after verifying your related fuses and bulbs are good
Old Dec 28, 2005 | 04:48 AM
mandolaire's Avatar
Thanks to all for their replies....Last night I was starting to work on on all the the small things before tackling the combination switch. I started with the fuse panel...and I found a blown fuse. I replaced it with a 10 Amp fuse and the signal lights worked.
Looks like I'll be returning the flasher and 8 bulbs. Thanks again for your help.
John
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
colinmil
Jul 6, 2015 04:03 PM
Steezy96yota
Jul 6, 2015 10:00 AM
wilbertd
Jul 6, 2015 07:39 AM
