General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Relay Help
Old Nov 22, 2006 | 05:00 PM
AxleIke's Avatar
Relay Help
Put in the rock lights today.
I have 5 total, 2 in the front bumper, 2 in the middle, and one over the rear diff. front two and middle two are working, rear is not
I have it wired like this. Power from batt to relays, 2 lights per relay, except the rear one. The rear one is on it's own relay, but the relay is designed for two lights. The relays are properly wired to switches, AFAIK.
Is there any chance that there being one light on a relay that is designed for two would make the light not work?
Old Nov 22, 2006 | 05:25 PM
son209's Avatar
It wouldn't make a difference. Each relay is good for about 30amps of current and it doesn't matter how many lights are hooked as long as it doesn't pull more than 30amps. If you have a light that's not working you need to check the relay and check to see if you have power and ground.
Old Nov 23, 2006 | 09:50 PM
rcars4life's Avatar
I have a similar set up, 1 light on a 2 light relay. works just fine, pull the relay apart and make sure it isn't all corroded, that would be my guess since its out in the open...its not mounted upside down is it? Check grounds and actual bulb.
Old Nov 29, 2006 | 09:33 AM
L33T35T 4Runner's Avatar
ya check the obvious things first, check to see if the bulb is good. hook a jumper wire directly to the light, see if they go on. then check your relay wiring
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
Rcbc92
Sep 26, 2015 03:00 PM
runnermedic
13
Sep 21, 2015 05:20 PM
