General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Need some help
Old Jan 8, 2017 | 09:36 AM
Kasan Blake Shedd's Avatar
Need some help
So I pulled my motor out to do a rebuild and I've got it all back together and it will crank but not start. It's giving me two codes pretty much saying I don't have an AFM but I tested it and know it's good. I did however find a plug that was disconnected and was wondering if that was my problem and where it goes. It's a 94 3.0. Any help will be appreciated I need to get it running asap it's my daily and I need it😂
Old Jan 8, 2017 | 12:06 PM
wyoming9's Avatar
Red face
Well is the plug on your AFM ??
Maybe you bent a pin on the AFM plug
Pinched some wires doing the pulling and install
Have the ECU ground wires hooked up ??
Old Jan 8, 2017 | 04:44 PM
DallasTX's Avatar
I think that loose connector in your picture is the knock sensor.
I just rebuilt mine too, and it seemed to take a lot of cranking at first to get it started. I am wondering if it takes a while to clear the air out of the injector lines. Jumped the test circuit to run the fuel pump for a couple minutes before attempting to start mine, but even after cranking several times, the plugs were still dry and did not even smell like gasoline. Eventually started.
Old Jan 9, 2017 | 08:00 AM
Janos01's Avatar
Make sure the plug from the disturber to the ignition coil is seated properly as this can cause the engine to turn over but not start as well.
Old Jan 9, 2017 | 08:42 AM
Co_94_PU's Avatar
2nd, knock sensor
ED1 two place black connector, black wire to ECU knk, brown to E1 ground point.
