General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
need to replace shifter, ignition and climate lights
Old Sep 12, 2007 | 04:18 AM
highmilesrunner's Avatar
Question need to replace shifter, ignition and climate lights
i have been reading the posts to do with replacement bulbs for the shifter light, ignition light and the climate lights and i know which bulbs to use. the problem is that i do not know how to access each of these areas to get to the bulbs to replace them. can anyone help me with this?
Old Sep 19, 2007 | 07:08 PM
rowdy235's Avatar
The shifter light is easy on most trucks, just take out the screws on the side and lift up the cover, you'll be able to see the light. Then just take it and get a new one.
Old Sep 19, 2007 | 08:58 PM
dropzone's Avatar
Fossilized
Dunno what year you vehicle is, might want to add that to your signature, helps people give you advice on the correct vehicle.
But if you have got an '85 or new one, this is a link to a Factory Service manual page that you might find helpful:
http://www.ncttora.com/fsm/index.html
Old Sep 25, 2007 | 06:25 PM
rowdy235's Avatar
climate light will either be above the controls or behind the controls.
If its a <1984, above the controls, remove the two screws and pull down the unit. PUll on the fixture on the back, and the light will come out. If its behind, pull off speed knob, and all the end caps on the levers, remove the nut on the speed selector, and pull the faceplate off. It should be visible from there.
Hope this helps
Jun 1, 2021 01:51 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
msane99
Jul 11, 2015 08:08 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
colinmil
Jul 6, 2015 04:03 PM
