General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
motor wire harness 89 3.0 into a 94 3.0 Truck
Old Aug 22, 2014 | 03:45 PM
tango2's Avatar
Hi there 1 have a 1994 toyota 4x4 with a bad 3.0 but i have a good 1989 4x4 3.0 that i would like to put in the 1994, I know the motor wire harness is different could i take the one off the 1994 and put on the 1989 thank you
Old Aug 23, 2014 | 01:00 AM
Terrys87's Avatar
I don't know the 3.0 but most likely you would be best to add the 94 components to the 89 motor.
Old Aug 23, 2014 | 05:16 AM
down4denver's Avatar
I don't know if this is very much help, but I'm in the process of doing a 3.4 swap into my manual 94 xtracab. I didn't want to mangle the 3.0 harness for when I go to sell it so I snagged one off an automatic 91 4runner at the junk yard and was somewhat surprised to know all the wires were the same besides two having different colors. So in your situation I'd be pretty certain that if you swap harnesses and ECU's you would be in good shape. I would certainly use the ECU'S that goes to that harness as all 4 plugs plug into it, Just as long as they both have the same type of trans.
Old Aug 23, 2014 | 05:31 AM
tango2's Avatar
do you know if most parts are inter changeable like intake and injectors? that looks like where most of the wires go. Just dont want to tare both down and find out i cant put new parts on the older motor. Thanks for the help
Old Aug 23, 2014 | 08:25 PM
I'm no expert but I don't think anything changed through out the life of the 3.0. I guess a good way to make certain the parts can interchange is to look them up via eBay or your favorite parts store and see if the part is compatible with both your years. I'm almost 100% certain that everything is interchangeable. Again, I don't want to be the voice of Toyota here. Hope someone certified will post. Good luck with the swap.
Old Oct 31, 2014 | 05:16 PM
1980lwb's Avatar
Not sure if you ever got the motor put in or not but someone else may need to know. I put a 93 motor in my 88 and the knock sensor injectors and throttle body are different on my end. The knock sensor I just spliced the wires together . The injectors I shaved the tabs off since that was the only difference. I put my upper intake on from the 88 so no changes on the throttle body. Hope it helps. Also oil pressure swith was different. Along with drivers side exhaust manifold.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
Yota.Jay
Mar 6, 2016 11:02 PM
bigblue82
10
Jul 6, 2015 08:27 AM
TheManOutside
Jun 18, 2015 03:32 PM
Yoda
Jun 23, 2002 09:39 AM
