missing harness?
missing harness?
i have a 83 sr5 4x4 and uh what are these to? i found them tonight when i put my dash in. looks like a relay
this is looking into the glove compartment i took out the inside of it to see this
this is looking up at the.... relay i think?
the other is to the right of it on the kick pannel in not sure what they plug in to any help would well help
thats an aftermarket relay, who knows what it was for, those connectors may or may not go to anything, Toyota sometimes used the same harness in all of the trim levels of trucks, so those plugs could be for an option you don't have
Dont worry about them just like said you just dont have the option on what the plugs are. Toyota saves money making one to three harnesess. you could add the missing part easier but why think about them if you dont have them as an option. pull the relay off on the top of it it may say what its for
i took out the relay and tooka pic but its not to clear
i just thought that those plugs hooked into this relay or something, i think ima get a chance to check out a picknpull today so ill check out whats there on other trucks
Relay
The relay is not a Toyota relay. The plug is for an option you don't have. Like stated before, Toyota only made one harness for that year of truck (gas). If everything works (in your truck) then nothing is wrong. Use the relay for something else.
The relay is a normally open, 30 amp, 12 volt, single pole.
Looks strangely similar to my "Charge Lamp Relay". Toyota wants $80 for it. Does your charge light work? My CLR broke so mine would come on at random times. After finding out the price, I just threw it away.
Just a shot in the dark.
Oh an PS, my truck does not have anything where yours in mounted. My Charge Lamp Relay was mounted to the passenger side kickpanel
Jayboy74
10
Dec 21, 2021 08:27 AM
terminator
Jul 27, 2015 07:13 PM
