General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
installing a fan 12 volt fan:help:
Old Jul 14, 2007 | 09:51 PM
bull307's Avatar
hi there i recently bought a small rotating fan from walmart that i can screw onto my dash. this will help with my AC problem but the problem is it plugs into your cigarrettelighter and i already have something in it, additionally it has a loonnnggg cord which would drape down over my stick shift which would get in the way
so my question is can i slice off the cigg adapter and run the cord over to my accessorry fuse and have it turn on when i want like i did with my CB Radio?
also a problem with that is i have the cb wire alredy straped the the fuse can i have another on the other side of the fuse?
and last question is that the wire itself has two seprate wires into one wire, do i connect both wires to the fuse or ground one of them like the CB?
im kinda leaning twords both on that one becuase i think when your wireing something to the frame of the vehical its to get reception
any help would be great
thanks, John
Old Jul 14, 2007 | 11:28 PM
Kaleb's Avatar
I would suggest you pick up an inline fuse form any auto store, and wire the positive wire with the fuse inline directly to your battery. Then put a switch inline with the ground. That way you don't have to tap into anything, and you can use the fan even if the truck is off.
80Truck
Oct 12, 2025 07:25 PM
SubiKing
Aug 21, 2021 03:57 AM
coryc85
Sep 9, 2015 06:24 AM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
zd92655
Jul 5, 2015 04:25 PM
