General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
How much overhead on a 60-amp 22RE?
Old Nov 20, 2017 | 10:05 PM
Vole's Avatar
I'm looking at doing some electrical upgrades soon, and I don't want to risk overloading the alternator. I was wondering just how much amperage is safely available for additional accessories. I'm upgrading the audio system, which includes a 300-watt amplifier (20 amps) , and I'd like to add in heated seats, which I've read are 7.5-10 amps each. The only other thing I have on there is a 120 watt led light bar, which uses about 8 amps when it's on.
Old Nov 21, 2017 | 04:09 AM
muddpigg's Avatar
if I remember correctly answer is inYT faqs or pirate faqs. It’s not much if memory serves you’ll be over taxing alt. You also need to consider the charging curve of your alt and what RPM range you want it to perform at. Also look at a big 3 upgrade but technically should be called a big 4 upgrade. I’ve stepped up alt a couple times. But not a big fan of the 1-wire setup; I like the charging light to function. Also the speed an alt turns effects is charge at idle but need to figure max speed as over spinning an alt is bad.
Old Nov 21, 2017 | 05:12 AM
dropzone's Avatar
Fossilized
one thing to do is not turn all that crap on at once.
I converted every bulb on my 81 including the headlights to LED, it helped to keep the alternator happy. I have done the same thing with the exception of the dash (it will get done) with the same goal in mind
you could do a GM CS130 alternator pretty easily
or this
http://www.lceperformance.com/High-O...-p/1080005.htm
