General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
HID's interfere w/radio
Old May 16, 2007 | 05:34 PM
too-many-hobbies's Avatar
Does anyone have a problem with radio interference when they turn on their HID's? I only get 1 station when they are on. But the second they are shut off - no problem. Is there a way to eliminate this problem? Some type of electrical wrap over the ballast or wires? Any info would be great.
Old May 16, 2007 | 08:21 PM
kevin444's Avatar
Bad grounding? Maybe the wires to ur stereo are to close to +12v wires?
Old May 16, 2007 | 08:39 PM
deserttoy84's Avatar
same thign happened with my hids. onyl with my cb radio though. i dont think its matter about grounding, the ballasts are loud and put out noises that radios pick up
Old May 17, 2007 | 09:32 AM
Yota Tony's Avatar
I'd put my money on a wiring issue.
Factory or aftermarket HIDs?
Old May 17, 2007 | 09:45 AM
HaveBlue's Avatar
It's the ballasts. I had a set of Catz Zetas that caused an enormous amount of interference on my CB. Everything was grounded properly. Even with a noise filter installed on the CB, I would get 2-4 bars of interference on the CB. Without the filter, I would get 6+ bars. As soon as I'd turn them on, the Tx power would redline and it would look like I had transmitted for a split second.
I ended up removing them.
Old May 17, 2007 | 10:04 AM
Erich_870's Avatar
Is the level of interference linked to the brand and specific model or can you have two identical ballasts but one produces significantly more interference?
Is there anyway to shield the ballast? Like my tin foil hat that protects me from alien mind probes?
Erich
Old May 17, 2007 | 04:15 PM
after market HID's on my 97 limited. It's pretty bad. There has to be a way to shield them?????
shooter86314
Jan 7, 2016 07:05 AM
clok
Nov 19, 2015 01:09 PM
Littlerick
Sep 10, 2015 08:57 PM
I8URSVT
Sep 3, 2015 11:42 AM
Blamalam
Aug 16, 2015 12:29 PM
