General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Fuses and what kind to use
Old Jan 4, 2011 | 01:58 PM
Uthro69's Avatar
Ok so i am hooking up a few things i want to have a on/off switch for
One is my Garmin Nuvi GPS
two is my Push button Starter
Three is 2 KC lights mounted on my roll bar.
Question is Can i run all of these to the battery with a switch in between or should i play it safe and get a fuse box and if so what rating of fuses should i use for each?
Old Jan 4, 2011 | 02:13 PM
justin_4runner's Avatar
i would use fuses on all three, 30 to 50 for starter, 5 to 10 for gps and 20 to 30 for lights but make sure u do a relay set up for the lights, u can make your own fuse block set up or pick up one that is used for sound systems, and u can hook it all up to a relay that will turn on and off by the ignition or switch. so it would be wire off batt to relay then fuse block and then to each item.
Old Jan 4, 2011 | 02:16 PM
Uthro69's Avatar
dont kc lights have there own relays?
So battery-relay-fuse box- items
i was just gonna run Battery to the Fuse box then have the fuse block run whatever switches i want
And what do you mean i can make my OWN fuse relay set up ? was just gonna order a fuse box or something from autozone or painless wiring
Old Jan 4, 2011 | 05:41 PM
they have wires that have the holders for the fuses built in, its usually 8ga wire and that is thick enough for what u are looking for, it sounded like u wanted to be able to turn off the fuse block when not using, that's why i was saying to do a batt to relay to fuse block.. if ur are not wanting to do that then i would do batt to fuse block. but u will want to run a relay for the kc lights any way u do it, if need i can draw up what im talking about.
Old Jan 4, 2011 | 07:08 PM
Uthro69's Avatar
if you could man id appreciate that ,,,
Old Jan 4, 2011 | 07:13 PM
Tofer's Avatar
Sponsor
Old Jan 4, 2011 | 07:39 PM
dropzone's Avatar
Fossilized
While you are at autozone pick up an auxiliary fuse box, and don't exceed the recommended amp ratings
Old Jan 5, 2011 | 12:08 PM
here ya go hope this helps.
86 87 4Runners
Sep 5, 2015 06:02 AM
bootscootboogie
Sep 5, 2015 05:57 AM
Gone Fission
Sep 4, 2015 12:18 PM
Scatterbrain
Sep 3, 2015 06:46 PM
86 87 4Runners
Sep 2, 2015 03:54 AM
