General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Fog light install problem
Old Jan 27, 2007 | 09:47 AM
Powerlineman's Avatar
I was wondering if someone could help me out. I just bought a set of PP fog lights for my 99sr5 4runner and when I went to connect wires underneath the steering column, they asked for different colored wires than what where there.
Does anyone know which ones I need to tap into.
Old Feb 11, 2007 | 10:53 AM
R1-4Runner's Avatar
You probably want to install to its own individual switch instead of tapping off of the factory wiring. It might fry the wires with any more current than it was designed to use. Unless a relay is being used... What is the total configuration your going for?
Old Feb 18, 2007 | 07:32 PM
rocktown's Avatar
if you install it hooked up to an auxiliary fuse block you can run the lights indepent of the factory lights. Ie, you can run the fogs with the lights off, low beam and high beam. plus its easier that way, no splicing into the factory wiring.
Charecter1
Nov 6, 2023 10:08 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
bryan34w
Jul 6, 2015 05:53 PM
colinmil
Jul 6, 2015 04:03 PM
