General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Flashing Overdrive light
Old Nov 9, 2009 | 01:09 PM
Yotalove's Avatar
Yesterday I tore out the entire interior on my (auto) 93 4runner and installed a new stereo, after putting everything back together and starting the truck up I decided to go for a drive and enjoy the new system, but the truck had trouble going as I had to rev it up to 3k rpm before she would move.
After a few minutes of driving I noticed that the OD light was blinking. So now I am thinking that I did something during the stereo install, I checked the computer, speed sensor but everything looks plugged in and connected.
Has anyone else had issues after doing a stereo install? Would a bad ground or disconnected wire cause the transmission to go limp?
I installed 2 amp, new deck, subwoofer, speaker pods with components, would a stereo that demands more draw from the electrical system cause it to shoot out codes??
The only stupid thing that I did was screw in a small shallow screw ( into the main electrical harness holder that runs down the passenger side (engine bay) to hold the stereo fuse, I have since removed the screw but OD still flashing.
Any input would be great thx! it is very possible I am assuming that its just a coincidence with the install and could very well be something else.
Old Nov 9, 2009 | 03:21 PM
Yotalove's Avatar
Well its not the wiring harness, I pulled the plastic sheathing off and all the wires are good no damage whatsoever.
Old Nov 9, 2009 | 04:19 PM
eric-the-red's Avatar
A flashing OD light means the computer has a stored trouble code. It could be from something you did, or it could just be coincidence. Check the codes and go from there.
Instructions are in here
http://www.ncttora.com/fsm/1990-1995...2/troubles.pdf
Old Nov 9, 2009 | 08:19 PM
Yotalove's Avatar
OK so I did the diagnostic and its giving me 6 flashes puase 2 flashes which is code 62 which means there is an issue with #1 solenoid. I suppose I will just have to bring her to the garage. Ty for the help Eric
chuckross1957
Jun 28, 2019 10:19 PM
crammit442
7
Nov 29, 2017 12:30 PM
Shoua
13
May 22, 2016 05:19 AM
AkitaDog
Sep 1, 2015 08:05 AM
keithporter83
Jul 24, 2015 07:37 AM
