General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Field Monitor Unit from a Surf into an LN165 Hilux - help!
Old Sep 1, 2023 | 12:55 PM
Tunafish7's Avatar
So I've got an FMU from a Hilux Surf to fit into my UK spec LN165 Hilux. It never came standard with it so everything will need to be wired from scratch.
I've read the pages on how to fit to a Forerunner so I've got the necessary colour codes for the wires and where to route them.
On most accounts I should be ok - I've bought an aftermarket ambient temperature sensor as it doesn't come with one from factory so hopefully that'll work, however the main issue I have is the unit wants to be wired to the ABS unit to calculate speed/direction for the compass. My model of Hilux has an analogue, cable driven speedo and no ABS...
Does anyone know of a workaround to wire up the FMU and allow the compass to function correctly via an aftermarket solution?
I've added a picture of my Hilux just for kicks
Thanks!
Paul22RE
Feb 6, 2020 05:11 PM
Aus_Lux
Apr 25, 2013 08:18 PM
NG Crawler
9
Mar 28, 2007 03:40 PM
metal22lica
Oct 17, 2002 12:24 PM
