General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
EFI fuse keeps burning in my FJ62 1988
Old May 24, 2010 | 03:01 PM
WalterIvanHurtado's Avatar
The EFI fuse [15A] keeps burning; I replaced with a 30A fuse and it ran for 300 miles before burning 2 more 30A fuses in 2 miles. Today, just for the fun of it, I put a 15A fuse and the truck ran for 30 miles before burning again. Any ideas, please?
Old May 24, 2010 | 05:17 PM
4Crawler's Avatar
Common cause is an O2 sensor wire that has burned insulation from contact with the hot exhaust, causing a short.
Old May 24, 2010 | 05:36 PM
1000 thanks
Thanks for such a quick answer; I will check the O2 sensor first thing in the morning.
Old May 24, 2010 | 08:31 PM
smarvin's Avatar
I would also say the o2 wire . I learned the hard way after being stuck on the highway and 600$ later they still could not fix it.. but thanks to google phones and this site i fixed it for $ 0.32 in a parkinglot
Old May 25, 2010 | 05:34 AM
Thanks Smarvin
Smarvin,
Thanks a lot for your input; now I believe my problem is bigger: before, if I did not have a fuse on hand I was able to "bridge" the two ends on the fuse slot but now, even putting together those two ends [that I plucked from the fuse box] the truck would not start. Any ideas at least to get it moving to take it to the shop, please?
Old May 25, 2010 | 06:56 AM
smarvin's Avatar
Look under the truck for sure ! check the o2 sensor wire for being melted
Old May 25, 2010 | 07:14 AM
Thanks Scott; I will go under it.
Walter
wafoogalla
Nov 2, 2016 11:02 AM
Duppie007
Aug 31, 2015 07:04 AM
hjalti_gto
Aug 24, 2015 11:46 AM
izzmee
Aug 17, 2015 10:20 AM
dpridgeon3
Jul 9, 2015 01:18 PM
