General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
ecu or not???
Old Dec 2, 2011 | 02:03 PM
edgewise's Avatar
ecu or not???
i have an 88 4x4 with efi. somthing seemed to be going bad on it, the batt.& brake light would go on & off randomly or when turning corners then died all together while turning a corner & wont start. 2 shops including a toyota specialist said it was probly the ECU, i tried a 89661-35150 ECU but mine is a -35110.... can anyone tell me if i need the exact #? P.S. they both said the injectors are gettin power but not a ground. i cant find any shorts or breaks. i tried to fire it on starting fluid, not even a fart......
Old Dec 2, 2011 | 08:56 PM
4Crawler's Avatar
Alt./brake light:
- http://www.4x4wire.com/toyota/mainte...nator_brushes/
Injectors are grounded via the ECU, check the injector wire splices:
Old Dec 5, 2011 | 07:20 AM
edgewise's Avatar
Thanks Crawler. This info is just what i needed. Hopefully I can check these soon. I learned a lot on here after I posted that. Seems to be a pretty common problem. Thanks agian. This site is priceless
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
bradahman
Oct 1, 2015 09:24 AM
Boomer8404
Sep 24, 2015 01:12 PM
Dobich
Sep 14, 2015 11:15 PM
zz_denis
Sep 6, 2015 03:43 PM
