General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
A/C question
Old Oct 24, 2006 | 01:02 AM
knowjesus's Avatar
A/C question
Just bought this truck: 87 Toyota 4wd, regular cab 22R. Want to get the a/c to work, the green light in the dash switch would not come on.....so I found the secret fuse behind glove box, fuse was blown... put a new 10 amp in and the green light came on like normal.
Problem is when I cut the a/c on and tried it, the compressor only turned for a second and it blew the "secret" fuse immediately.
Any suggestions??
I have not tested the freon level in the system yet, trying to start cheap.
Old Oct 24, 2006 | 02:08 PM
HAVOC's Avatar
shorted clutch perhaps?
Old Oct 24, 2006 | 02:21 PM
dcg9381's Avatar
That'd be my guess.. Or a short in the wires before the clutch.
Old Oct 24, 2006 | 05:39 PM
knowjesus's Avatar
Thanks for the ideas, anyone else have a theory??
Old Oct 24, 2006 | 06:03 PM
Bigblock's Avatar
clutch
Old Nov 19, 2006 | 08:48 AM
toyota_mdt_tech's Avatar
I's also say shorted magnetic clutch coil. But for grins, unplug the compressor, turn it on and see if ther fuse blows. If the mag cutch coil is shot, the clutch bearing is also probably gone and heated the coil up, burning away the insulation and shoirting it to itself and/or ground. Spendy repair!
MO transplant
Apr 23, 2023 11:58 AM
g3bill2
Aug 7, 2015 07:04 AM
stock87yota
Jul 31, 2015 10:08 AM
jackiebrownia
Jul 20, 2015 09:02 AM
bryan34w
Jul 6, 2015 05:53 PM
