General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Basics of fusing a circuit
Old Sep 12, 2013 | 04:17 PM
83's Avatar
83
I'm working on the wiring of my RV.
I don't know how to pick the correct fuse size. If I've got, say, two LEDs (maybe 1 amp together) and a fan which said "no bigger than 4 amp fuse" on the wire, do I combine the total amps of all the electronics to pick fuse size? Or what?
I did an overkill on the wiring, it's all 12 gauge. So fusing according to wire size won't work, here.
I'll have pretty low draw on all the wires.
So how do I go from what the appliances I have on each circuit draw, to deciding what size fuse to put on the circuit?
Thanks!
Old Sep 12, 2013 | 05:37 PM
phildelfino's Avatar
I do not know what the formula is but you have to go bigger than the highest draw. you could start with a 5A and if it blows too often, switch to a 7.5A. I would guess a 10A would be too much.
Old Sep 12, 2013 | 06:12 PM
smithyboy69's Avatar
Assuming everything is wired in parallel, the sum of the branch currents should equal the applied current, which is what you need to fuse for. The total current should be your voltage divided by your total circuit resistance.
Old Sep 13, 2013 | 12:02 AM
wyoming9's Avatar
Red face
So how does one figure circuit resistance ??
Old Sep 23, 2013 | 03:09 AM
Wannasas's Avatar
Resistance is voltage divided by current(amps).
Old Sep 23, 2013 | 08:53 AM
83's Avatar
83
Ok, thanks. I overdid it on the wire. I put in 12 gauge wire for circuits that probably don't have any more than 5 amps ever drawn on them, so the wire burning won't be a problem so long as I fuse for the appliances.
Bourbonblues
Dec 15, 2017 05:43 PM
anniesball
10
Sep 15, 2015 05:41 PM
EatChipsNow
Sep 9, 2015 01:25 AM
Rawwdz
Sep 6, 2015 09:03 PM
Gone Fission
Sep 4, 2015 12:18 PM
