General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Alternator short?
Old Aug 2, 2007 | 08:29 AM
Maverick's Avatar
Alternator short?
How does an alternator short out and blow a fusible link? I noticed on the alternator that I took off that there was only one nut on the post that you attach the cable to but on the new alternator I noticed two nuts so I left one on the post where it was and used the other nut to attach the cable. It ran for 15 minutes fine then all of a sudden all the electric went out, and the truck wouldn't start. The Dealer told me the alternator was installed wrong and that the fusible link was blown, what did I do wrong?
Thanks for the help
Mave
Old Aug 2, 2007 | 09:10 AM
WATRD's Avatar
It sounds like the dealer is blowing smoke up your skirt. A nut on the stud won't make a bit of difference. If you mounted the alternator to the bracket, plugged in any harness and connected any high-amp connection to the stud, without pinching any wires, there's not much in the install process that can go wrong.
Could be a pinched wire or a defective alternator.
Old Aug 5, 2007 | 12:22 PM
Maverick's Avatar
Ok thanks for the info, I'll take that into consideration.
Old Sep 9, 2007 | 09:55 PM
88-4RUNA's Avatar
is it blowing the 40a?
Old Sep 13, 2007 | 08:20 PM
rowdy235's Avatar
The only time i have ever seen a blown fusible link is on my friends 84. He was working on it while running (bad move on his part) and he dropped his wrench, it fell down and contacted the alternator post and block at the same time, blowing the link. Luckily, we were able to obtain and install a replacement.
Old Sep 14, 2007 | 03:13 AM
milo's Avatar
Coil and igniter not getting fire
sorry hit wrong post button
MadMax48
Mar 3, 2020 10:33 AM
scheuvront1993
Sep 17, 2015 06:17 PM
skouba
Sep 14, 2015 06:58 AM
