General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
93 Toyota P/U ~ Front parking light issue..
Old Nov 19, 2012 | 01:03 PM
fugger.nugg69's Avatar
Front parking lights worked until a couple days ago.. All other lights work ~ all tail lights, hazzard, headlights, blinkers, dash.. CONFUSED
Old Nov 19, 2012 | 11:25 PM
wyoming9's Avatar
Red face
Well what have you checked so far??
Did the blubs burn out??
Did you tear or damage the wires in some way???
Are the sockets corroded ??
Does this vehicle have a alarm??
Old Nov 19, 2012 | 11:39 PM
Scenic WonderRunner's Avatar
Check the.....Front parking light......FUSE!
Replace it!
Then go out on a fun 4x4 Outback trip......and be sure to Report back to us!
With Lot's of PICS!
......Carry On!......
Old Dec 7, 2012 | 08:11 PM
SPARKS89's Avatar
I doubt it's bad bulbs or sockets. What are the odds that both would go bad at the same time? Anything is possible tho so go ahead and check them. It sounds to me that the problem is upstream in the circuit. Of course, start with the easiest and most obvious...the fuse. If thats good then move on to the switch and wiring. Turn the switch on and check for voltage at the sockets. If you have that then you just eliminated both of them as the problem. Move on to the secondary side of the sockets and check your wiring and ground. If not then you know it's one of those two. Turn the switch on and check for continuity thru the switch with your multi-meter (if you don't have one you should). If that checks out move on to the wiring. Make sure the ground is solid and work your way along the wires checking for cuts or breaks inside the insulation. Bend the wire. If it's broken inside the insulation it will bend a lot easier at that spot than anywhere else. If you find a broken wire make sure you use a crimp-style butt splice to fix it. Please do yourself a favor and don't use a wirenut anywhere on your truck.....they hate vibration.
gillesdetrail
Nov 19, 2019 12:56 PM
Aleeex_u
Jun 5, 2016 06:52 PM
bobbybouche
Jun 18, 2015 10:22 AM
Mohamed
Jun 20, 2002 10:42 AM
