89 4Runner wiring harness
Is there a company out there making replacement engine harnesses or what other year trucks engine harnesses are plug and play compatible ,that would be in better shape to replace mine with , it is brittle and falling apart .
thanks
thanks
They are pretty much ALL brittle and falling apart.
No company makes a "direct" replacement plug and play harness. Painless wiring may be your best source. Otherwise, you are going to be making your own custom harness. If just the plugs are falling apart, you can try and locate donor plugs and depin/repin your plugs, then retape the harness and call it good.
Regency
20
Jan 3, 2020 07:43 PM
