General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
86 4Runner power windows. I want to redesign the circut
Old Apr 6, 2007 | 12:56 PM
80W90's Avatar
Hi.
Normally i wouldn't F with this, but since the PO removed the pass side switch and compltletly disassembled the drivers switch, and used those awful tweeker connectors for some of the existing wires, grounded wires that he shouldnt have, and charged ground wires, I am left with a giant mistake.
So now in order to get my window to go up and down, I just hot wire it directly at the motor connector.
I was thinking about this, how to first draw up a wire scematic, to use a total of four relays, and two up only switches, and two down only switches.
or use a double throw double pull switch. but with that one i dont know if I can run two circuts thru it with out them closing on one another.
has anyone drawn up a scematatic for this?
It is not nessicary for me to be able to operate the passenger window from my door. I can lean over and operate it.
Old Apr 8, 2007 | 10:21 PM
80W90's Avatar
i figured it out.
forgetta bout it.
Old Apr 9, 2007 | 05:31 AM
isaac338's Avatar
i know you've got it, but fyi there's no relays in the circuit at all. if you use a stock switch (junkyard) it's an easy wiring problem. it's all direct connections!
Jun 1, 2021 01:51 PM
jon.r
Jul 11, 2015 03:34 PM
nick b
Jul 11, 2015 04:38 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
skoti89
Jul 8, 2015 12:05 AM
