General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
85 intermittent wipers into 87 pu
Old Dec 8, 2007 | 10:01 PM
bleakhorizon's Avatar
Ok ive searched couldnt find anything.......sooo..... Im putting a tilt steering column from an 85 sr5 runner with Int. wipers into my 87 pu that is solid , with a off-low-high type windshield wiper switch, well my question is do i need more than just the new switch, is there a intermittent module under the dash somewhere (i would have it, i have the whole harness from old vehicle) but i have no idea what it would look like......
any who thanks........
Old Dec 9, 2007 | 12:20 AM
ok so after looking threw my chiltons it seems in an 85 truck/runner that there is an optional wiper relay that would control the int function.....the 87 does not show this option......has anyone done this before i think the relay is on the pass side beside the glove box but i am not sure......i will post pics if i figure it all out
Old Dec 9, 2007 | 10:38 PM
anotherjeff's Avatar
On the '85, the wipers will work "normally" with a transplanted column and switch, without the control box/relay (...just no variability). On the '85, there's a (1x3x4", bluish-green) control box/relay which resides next to the ECU. On the '85, there is a small (3 connectors?) wiring harness that patches the control box/relay into the main wiring harness.
Now, the '87 apparently has the function of the control box/relay, incorporated into the switch on the column. You may need to swap the dash wiring harness (...that's a fun exercise!). Or, maybe it's the same wiring harness, and you just need to patch in the control box/relay, like on a '85.
I have the parts, ready to install on my '85. If you need a better description of the harness, give a hollar.
Old Dec 9, 2007 | 10:56 PM
i have the original harness from the 85 i just have the WHOLE harness so its alot to look through, i havent even looked at my 87 but is there a connector on the pass side that i must plug the relay in between......its been hard for me lately to get out there and look (much cleanup needed after storm) and this is my DD so i need it to go as smooth as possible...... so thats why so many questions without any information on my part
puddlepirate
Jul 30, 2016 06:29 PM
pickle6415
Dec 25, 2015 07:34 PM
PNW94Runner
Sep 29, 2015 02:55 PM
jacked_72
Sep 14, 2015 03:31 PM
VT2LAB
Sep 10, 2015 09:36 AM
