The Slip Indicator & Multi-terrain select indicator warning lights on my 2019 4R TRD ORP are blinking and sometimes the 4WD Indicator Light does too, I've taken it to a local dealer and they couldn't figure it out, I'm not getting any error codes on my scanner
This started happening after a week off-roading Mojave trail, I've engaged 4W Hi & Lo and driven around, disconnected batteries to try and re-set and no luck
Any advise would be appreciated
Matt Slip indicator stays on and the MT light blinks
Hi Steve, Yes, it was the 4WD actuator, replaced and everything working as normal. I'm on my second replacement, the first went out about six months later, so far as good. Thanks
