General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
1993 4Runner speedometer
Old Feb 12, 2023 | 12:53 AM
Milzy98's Avatar
1993 4Runner speedometer wiring
Hi everyone, not sure if I’m posting this on the right spot but
I have a 93 4Runner the speedometer isn’t working it’s electrical driven and so is the tachometer (checked to make sure they matched up) but it’s had a 95 model 3.0 swapped into it (not sure if there’s much difference if any) not to sure on the gearbox and transfer but the plug doesn’t seem to be there for the speed sensor I’ve tried tracing harnesses back through the car and checked ontop on the gearbox but nothing, is there a seperate plug that is suppose to plug into one of these plugs? That’s all I have sitting around the gearbox. The 4wd light also doesn’t work as it seems like a plug is missing from that sensor aswell
is there anywhere I can piggy back off to get a signal if the plug is non existent?
cheers
millsy
Old Feb 12, 2023 | 03:21 PM
millball's Avatar
!995's were built with mechanical speedo.
Old Feb 12, 2023 | 03:24 PM
Milzy98's Avatar
So im guessing they’ve used the 93 box and 95 engine and harness? Is there anyway I can splice into this harness and put a sensor connector on to complete the circuit?
Old Feb 12, 2023 | 03:28 PM
millball's Avatar
I don't know.
Maybe someone else can help.
924runner4wd
Apr 2, 2015 03:09 PM
RevJoE
Feb 9, 2015 02:08 PM
funpow
Mar 9, 2012 08:54 AM
YFZsandrider
Oct 19, 2009 11:30 AM
