General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
1992 Toyota Pickup Base 22RE 5-Speed LED Lighting conversion
Old Mar 4, 2015 | 01:30 PM
bswarm's Avatar
1992 Toyota Pickup Base 22RE 5-Speed LED conversion...
Front Parking (White, Should have ordered amber but they work OK) -
Amazon.com: Cutequeen 10PCS LED Car Lights Bulb White T10 2835 4-SMD 80 Lumens 194 168 (pack of 10): Automotive Amazon.com: Cutequeen 10PCS LED Car Lights Bulb White T10 2835 4-SMD 80 Lumens 194 168 (pack of 10): Automotive
License Plate (White) -
Instrument Panel (Blue) -
Amazon.com: Cutequeen LED Car Lights Bulb Blue T10 5050 5-SMD 194 168 (pack of 8): Automotive Amazon.com: Cutequeen LED Car Lights Bulb Blue T10 5050 5-SMD 194 168 (pack of 8): Automotive
Heater Control (Blue) -
Amazon.com: Jtech 10 x T5, 5050 SMD LED Blue Car Lights Bulb: Automotive Amazon.com: Jtech 10 x T5, 5050 SMD LED Blue Car Lights Bulb: Automotive
(Had to slightly trim the bulbs base to fit the socket with a Dremel)
Backup (White) -
Amazon.com: TuningPros LEDBL-1156-W19 Backup Reverse LED Light Bulbs 1156, 19 LED White 2-pc Set: Automotive Amazon.com: TuningPros LEDBL-1156-W19 Backup Reverse LED Light Bulbs 1156, 19 LED White 2-pc Set: Automotive
Rear Turn Signal (Amber) -
Amazon.com: JDM ASTAR Super Bright AX-2835 Chipsets 1156 1141 1073 3496 7506 LED Bulbs for Turn Signal,Amber Yellow: Automotive Amazon.com: JDM ASTAR Super Bright AX-2835 Chipsets 1156 1141 1073 3496 7506 LED Bulbs for Turn Signal,Amber Yellow: Automotive
Front Turn Signal (Amber) -
(I had to file the LED board very slightly to get the bulb all the way in the socket. And the polarity was reversed, rather than cut and splice the wires, I disconnected the socket, removed the black wire connector lock, used a pick to release each terminal and swapped sides in the connector housing)
Brake (Red) -
Amazon.com: JDM ASTAR Super Bright AX-2835 Chipsets 1157 2057 2357 7528 LED Bulbs For Brake Lights Tail lights Turn Signal, Brilliant Red: Automotive Amazon.com: JDM ASTAR Super Bright AX-2835 Chipsets 1157 2057 2357 7528 LED Bulbs For Brake Lights Tail lights Turn Signal, Brilliant Red: Automotive
Flasher Relay -
Amazon.com: Tridon EP35 Flasher: Automotive Amazon.com: Tridon EP35 Flasher: Automotive
Dome Light - I had no luck finding a 25mm festoon bulb. I have an overhead shelf so it wouldn't be much use anyway. The shelf has a 1" hole on each end, so I'm putting these in and wiring it to the existing dome light. https://www.superbrightleds.com/more...ure/1536/3460/
One problem... When I step on the brakes the parking lights and instrument panel lights come on slightly dim. I've checked the brake lamp sockets for a short between terminals, it's OK. When I replace either side brake lamp with a standard bulb, it doesn't do this. I don't hear the parking light relay clicking when stepping on the brakes, so it must be feedback voltage through the LED bulbs. Perhaps a different LED bulb may fix this, or adding a diode to each rear light assembly.
I also did the Hella headlamp conversion along with the wiring harness/relay upgrade, best headlamps I've ever had on this truck since I bought it new in 1992.
Old Mar 4, 2015 | 02:07 PM
bswarm's Avatar
I did some searching, I'm going to have to add a diode to each rear light assembly.
Different bulb but same problem and solution...
http://v-ledsblog.com/2010/11/19/whe...s-turn-on-why/
Old Mar 4, 2015 | 03:18 PM
bswarm's Avatar
Since electronics is a hobby of mine, I had plenty of diodes in my stock of parts. I put a 1N5822 diode in each tail light assembly on the parking light wire. The diode is good up to 40 volts and 3 amps so I should never have a problem with it. Parking/Instrument lights no longer come on with the brake lights. Problem solved, everything works.
Old Mar 4, 2015 | 05:49 PM
bswarm's Avatar
I guess I should have posted this thread in the "General Electrical & Lighting Related Topics"
Any way to move it there?
Old Mar 5, 2015 | 02:07 AM
dropzone's Avatar
Fossilized
interesting, my entire truck has been converted to LED and had no issues that required the addition of a diode.
Moved for you and tweeked the title slightly
Old Mar 5, 2015 | 05:58 AM
bswarm's Avatar
I think some LED bulbs that replace dual-filaments have the diodes built in, I got some that weren't.
Old Mar 16, 2015 | 01:40 PM
bswarm's Avatar
I installed a digital tach next to the dimmer control today...
Old Mar 30, 2015 | 07:59 AM
Cthulhu's Avatar
OK WELL now I know what to do with my tach. I never bought one because I could never decide where to put the thing. Not to steal your idea but that looks clean!
Old Mar 30, 2015 | 11:28 AM
bswarm's Avatar
I did have to slightly dremel the support area behind the dash panel, but not so much as it would weaken the structure. You're also not going to get anything larger than a 2" diameter gauge in there.
Old Aug 31, 2018 | 12:14 PM
bswarm's Avatar
It's about to hit 68,000 original owner miles. Original clutch, rear brakes, but I did have to replace the valve cover gasket when I did the 60k service.
Aleeex_u
Jun 5, 2016 06:52 PM
Gamble_STi
Jun 27, 2015 07:54 PM
94hiluxZE
Jun 22, 2015 10:42 AM
paxanders
Jun 21, 2015 06:29 AM
infinityisfive
Jun 16, 2015 06:51 PM
