Alarm Systems Discussion related to installation, diagnostics, and purchasing of alarm systems
97 4runner wiring VIPER alarm help
Old Apr 10, 2016 | 05:17 PM
kolelt's Avatar
I have a 97 4runner. With factory alarm and key fob. I just purchased a Viper 3305v alarm. Because I want a better fob and more distance and security. I used the wiring diagrams of the Internet.
I want to keep the horn as the alarm sound and not use the ugly speaker they provide.
So I'm Little lost. I found most wires. Except few. On the VIPER alarm it is saying. CHANNEL 2 OUTPUT : connect to vechile negative trunk releat relay or other low current device. To my knowledge there's no trunk release output on 97.
And on VIPER alarm it's saying channel 3 output : connect to an auxiliary relay or low current device.
Wtf is low current device in a vechile ?
For door trigger it's asking for + and - , and on the wiring diagram for the 4runner they only give you - I'm guessing to make it work properly I need to find a + to ?
Also for siren output: connect to the + wire on the siren or horn. The wiring diagram for the 4runner is only giving you a - horn wire. Will this work ?
And seriously, what do you do with the factory alarm ? It's wired into the PCM. If you disconnect it the car won't start. So how does that work? What do I do with factory alarm
Old Apr 10, 2016 | 08:12 PM
kolelt's Avatar
Bump, could really use help
mtnkid85
3.4 Swaps
13
Jan 26, 2026 04:58 AM
Vernsyota
Mar 7, 2016 04:41 PM
gotduhka
Mar 5, 2016 09:21 AM
frzr
Feb 27, 2016 01:52 PM
atoliver
Feb 11, 2016 01:03 PM
