95 4runner viper 3203 install HELPPPPPPP
Hi,
the truck is 1995 4runner and im installing a viper 3203 alarm. I found all the wires and hooked everything up BUT the door locks. I found the door lock wires plugged into the relay box behind the driver side speaker.
But i cant figure out which wires from the alarm are supposed to connect to the car.
Ive installed a few viper alarms before but this one is different, being that it has a seperate harness just for door locks with 8 wires. All other dei alarms ive installed just had the simple 2 wire door lock harness with green and blue wires.
here's the install guide ive been using.
can someone PLEAAAASE tell me which wires to connect to the door locks. Everything else seems to work fine.. thanks
jerusry
Oct 19, 2015 05:28 PM
