What's wrong with your 4Runner, round 2
Old Jul 1, 2006 | 04:13 PM
terryjmatthew's Avatar
Nada! It does help to work at a Firestone. Anytime we are slow, my truck is on the rack getting some sort of work performed.
I guess that would explain why I have had three sets of tires in the last year and a half!
Old Jul 1, 2006 | 04:20 PM
msw0085's Avatar
^ throw some love my way with those tires!
Old Jul 1, 2006 | 06:00 PM
4banginRunner's Avatar
1.Trans need a rebuild
2.needs an exhaust system (glasspacks to loud + leaks like a SOB)
3.O2 sensor
4.Rear is sagging
5.front seal is leaking
6. its a 2nd gen (i need a 1st gen to be happy)
Old Jul 1, 2006 | 06:23 PM
ebelen1's Avatar
I guess my complaints are tiny compared to others:
1. My SAW's squeek only after going over speed bumps w/ some decent speed. It's not when I hit the bump but when I come back down.
2. Raybestos brake pads like to squeel at start up but perform really well after warm-up. One good thing is that there is very little brake dust. The worst part about the squeel is that everyone at work keeps telling me I need new brakes and it's pretty embarrassing at a valet.
3. My JL amp went out (still powers but equalization sucks). I had to swap it out for an Alpine. Sweet sounds once again.
4. The extra lift the OME 891's gave me in the rear causes more sway on the highway at decent speeds (>70 mph). I have some new fabbed end links from Wabbit that I'm hoping will help with this. Also waiting to install my SS panhard bar at the same time.
Other than the bumpy ride a truck gives you, I love my runner...
Old Jul 1, 2006 | 06:24 PM
  #25
ebelen1's Avatar
Originally Posted by Localmotion
5. rotors are starting to warp again
Didn't you go Tundra rotors and calipers?
Old Jul 1, 2006 | 06:53 PM
  #26
gohawks's Avatar
1) Hard start sometimes when hot......coolant temp sensor perhaps? Not a real issure yet.
2) Need to have tires rotated.
3) Doesn't get driven enough. 7k in 1.5 years.
Old Jul 1, 2006 | 07:25 PM
  #27
Got some 265/75R16 Destination MT's in the garage right now.
12-13/32". No patches, plugs, etc.
Feeling froggy???
Old Jul 1, 2006 | 07:39 PM
  #28
frankjake's Avatar
1. Tint on rear window needs replacing.
2. Need tint on the front dirvers/passenger windows.
3. Oil pressure guage doesn't work
4. Rear bumper has two rust spots
5. Rear passenger side door window slipped off track
Other than this, everything else seems fine. Of course would love more power and better mileage, only about 16 mpg.
Old Jul 2, 2006 | 12:26 AM
  #29
X-AWDriver's Avatar
My front license plate took a shot from some semi tire tread being thrown into it and it's far from being perfectly straight now but if that's all I have to complain about then I'm happy otherwise at 116k every other single thing actually works including the power antenna.
Old Jul 2, 2006 | 06:54 PM
  #30
nmtoy's Avatar
It's really slow, other than that it's great!
Old Jul 2, 2006 | 07:52 PM
  #31
bob200587's Avatar
I've got an oil leak somewhere towards the rear of the engine
Need to change my gear oils to synth, but they're expensive
Hi-beams don't work
Spotlights work intermittently
shifter is sloppy, needs the little thing on the end
my HVAC control panel is cracked in 3 places
My fresh roll on bedliner is scraped off in the bed.
There is dirt EVERYWHERE and I can never keep it clean
All 5 of my wheels are bent
My rear bumper is holding on by a thread, and I can't afford a Sonoran Steel yet.
I don't have a winch
I don't have lockers
I don't have dual batteries
I don't have _________ (insert just about anything)
My ball joints are popping, I proabably need new ones and I need to do BJ spacers too.
My engine could use a rebuild.
I could go on, but I'm not.
Old Jul 2, 2006 | 08:29 PM
  #32
Lysmachia's Avatar
Originally Posted by MossyRocks
I was being lazy, Im in the process of getting parts for the swap... I have 215k on the runner and AFTER I started collecting parts this started;
1-power steering acting up again
2-something feels loose in the front (probably the next issue)
3-steering bushings are worn out
4-DS cv is slinging grease
5-rotors are warping again
6-skidplate is un-recognisable
7-not enough flex (not fun on steep off camber descents)
8-OME coils aren't strong enough for a winch bumper
Mine had 215 when she got the swap (gawd I make her sound like A TRANNY!)
The thing I noticed... The tranny was slipping as I kept driving her to Moab (360 miles - 6 hours) Till I got a Tranny Cooler and did a full flush 3 times. Now My rear window just won't go up. But I'm not so sure that's because I don't wail on her...
Oh and for the record she's got 571 gearing with Auto.... DAMN!
Oh and Mossy, get yerself some FROR Steering armor...and sterring arms. It fixed my steering issues in a jiff!
Old Jul 4, 2006 | 01:34 PM
  #33
da_bigg_wigg's Avatar
1) rear diff noise
2) damaged bumpers front and back
3) rear window needs a lot of lovin' to get up these days
4) spare tire is a permanent fixture due to messed up rear bumper
5) a/c shot (not that i use it)
Old Jul 4, 2006 | 01:39 PM
  #34
gregbreakseverything's Avatar
Dash fan clicks at slow speeds, and roars and shakes the whole truck at full blast.
p.s. wiggy, your runner is mint compared to these other guys. I may be the only guy with his runner body in perfect shape.
edit: turned out to be a mangled mouse corpse in my fan. stupid mouse, no match for toyota. It did take 2 days to rip it apart and clean though. I still think I won.
Old Jul 5, 2006 | 02:38 AM
  #35
91 4Runner's Avatar
Relay Rod needs to be replaced - just got the recall in the mail...
Tranny pan needs to be resealed
Fanbelt needs to be replaced
O2 sensor needs to be replaced
Passanger side Rotor needs to be replaced
Need to fab a new front skidplate - turned mine into a Taco
Headlight needs to be replaced
3 wheel studs need to be replaced
Then onto paint and body
Old Jul 10, 2006 | 12:47 PM
  #36
doug's Avatar
motor problems
hey guys i have a 1990 toyota 4 runner that i just did the head gaskets because it had blown head gaskets it gets oil, gas, spark any ideas?????????
Old Jul 10, 2006 | 12:48 PM
  #37
doug's Avatar
motor problems
hey guys i have a 1990 toyota 4 runner that i just did the head gaskets because it had blown head gaskets it gets oil, gas, spark but wont start any ideas???
Old Jul 10, 2006 | 01:15 PM
  #38
User 051420's Avatar
Psst..you'd be best off deleting your two posts, and putting your question in an appropriate thread.
Old Jul 11, 2006 | 01:03 PM
  #39
MossyRocks's Avatar
I think that is his sig, "motor problems" was the post
Old Jul 11, 2006 | 04:21 PM
  #40
surf4runner's Avatar
rear bumper keeps getting dented when i back-up into the wall (its ok now, i finally knocked the wall over)
its not a 4X4 and is an auto. still fun
warped rotors - replaced w/ flat brembos, 5000mi so far no prob.
elec ant has never worked.
driver is a lunatic.
