what grade fuel do you use?
Old Feb 9, 2006 | 08:47 AM
noahrexion's Avatar
eww, so does that mean that 85 is low grade? I can't imagine using that, whew
Old Feb 9, 2006 | 08:50 AM
KyleT's Avatar
theoretically you can make more hp with the lowest octane....(lower the octain, the faster the fuel burns) but increases the risk of failure.
Old Feb 9, 2006 | 08:53 AM
surf4runner's Avatar
Originally Posted by TomCham
The only gasoline we have in Hong Kong is Octane 98 US$7.22/gallon
is this correct? or did you mean 89? i cant even find 93 out here, best is 91 (unles you have a friend at the airport )
i use 87 all the time, least expensive, but NEVER arco=cheap.
Old Feb 9, 2006 | 10:05 AM
CynicX's Avatar
87 before S/C without any problems. I think it ran best on 87, thats what Toyota recommends anyway....
Old Feb 9, 2006 | 10:32 AM
  #25
snap-on's Avatar
87 with 10% ethonal as thats all we can get in STL area.
ive run the lamp oil stuff they sell out west before <cough 85 cough>
Old Feb 9, 2006 | 10:39 AM
  #26
MTL_4runner's Avatar
No, he means 98 octane (unleaded too!!!).
....it is crazy over there, they basically sell race gas at all the pumps (you can't get low octane gas, period).
Old Feb 9, 2006 | 11:33 AM
  #27
jeremys73's Avatar
Originally Posted by bob200587
93, almost every time. I'm running some tests on 89, but so far 93 gives me substantial increases in MPG.
I'm going to try this. I just got my 4runner, it has 14000 miles on it. I've kept track 3 times now. 1st was 20mpg, 2nd was around 18mpg and this last one today was 19.9mpg. So if this is true, I should see 21-22. I run 87octane from wal-mart... paid $2.06gal today
Old Feb 9, 2006 | 11:41 AM
  #28
bob200587's Avatar
MPG
21
18
18
20
18
19
19
17
18
15
17
Grade
93
93
93
93
93
93
89
89
93
93
93
Thats my log to date, I think some of the numbers have been affected by pretty big changes in temperature. I don't even know if you can even read it like it is, but I couldn't upload a Excel file.
Edit: I just showed the Grade and the subsequent mileage. These figures compensate for change in tire size and are about as accurate as can be.
Old Feb 9, 2006 | 12:19 PM
  #29
99runner4me's Avatar
87 octane, mostly Costco gas. No cheap stuff like Arco, Thrifty, etc., etc.
I put the occasional "Lubro Moly" Ventil Sauber(valve clean), "Lubro Moly" Jectron(fuel injector cleaner), Or Chevron fuel injector cleaner every 2-3 gas tank full.
Old Feb 9, 2006 | 04:01 PM
  #30
Paul H.'s Avatar
89 in the 4runner, 87 in the Taco.
Old Feb 9, 2006 | 08:02 PM
  #31
kyle_22r's Avatar
cheapest stuff i can find. just because it's a toyota doesn't mean it needs special gas. my chevy work truck, on the other hand knocks like a snare drum if you mash the gas unless we run 93 in it...then again, it's got a high dollar stroker engine in it...
Old Feb 10, 2006 | 09:43 AM
  #32
98taco4x's Avatar
87 here as well in a 98 tacoma 122,000
Old Feb 10, 2006 | 10:02 AM
  #33
87TurboYota's Avatar
87, the higher grades are just a waste of money unless your motor uses it specifically, supercharger, or other high performance goodies. I look for the most inexpensive 87 octane I can find.
Old Feb 10, 2006 | 11:08 AM
  #34
edikp's Avatar
87; been buying it mostly at CostCo.
Old Feb 10, 2006 | 10:34 PM
  #35
youngbuck's Avatar
User manual says 87, but since I am high elevation (Colorado > 1 mi. high) 85 is just fine, and no advantage whatsoever going to 87.
Old Feb 11, 2006 | 02:07 AM
  #36
toywheelin05's Avatar
i run 89 through my 22re, it seems to like it better. my yamaha r6 on the other hand....i run 103 in that baby. cracks like a whip when u grab the throttle. doesnt even compare to 92 or 94.
Old Feb 11, 2006 | 10:16 AM
  #37
4unner4life's Avatar
I run 87 in my 3.4 and 93 in my honda cr dirtbike.
smthwsn357
May 1, 2024 07:28 AM
wafoogalla
Nov 2, 2016 11:02 AM
daddio
Aug 9, 2015 07:17 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Fundy Rider
Jul 16, 2015 01:35 AM
