weber 38...just for the record
Old Jul 1, 2012 | 07:56 PM
cyborg-64's Avatar
i bought a truck a few years ago with a weber 38 and an inline elec pump. worked ok, made a little noise. the pump burned out and i replaced with a carter 4070 after reading through the yotatech forum archives. the carter was way loud, so loud that everyone always asked what was buzzing. it was very loud and i couldn't stand it anymore so i put the stock mechanical pump on and guess what... it runs just fine, better than ever, in fact... so if you are gonna run the weber 38, i want you to know that the stock pump works perfect for me. make sure to connect to your fuel return line and it should be aces.
Old Jul 2, 2012 | 07:10 PM
myyota's Avatar
Yep, the stock fuel pump is more than enough to work with the weber 38.
Old Jul 29, 2012 | 08:24 AM
85GT-79FJ40's Avatar
A weber only wants to see 4-5 PSI of fuel pressure and most of the generic carbed electric pumps put out 8-10. So yes I bet it does run better. Especially if the stock pump on yours has a return line and it's hooked up.
Old Aug 24, 2012 | 05:18 AM
ilovelivinginthecity's Avatar
ladybugRC
458
Aug 21, 2020 10:41 AM
Pri$erulz
Nov 17, 2019 08:03 PM
highonpottery
Nov 22, 2015 03:57 PM
kawazx636
Sep 29, 2015 08:22 AM
4Xtruck
16
Sep 24, 2015 09:38 AM
