transmission flush at 147,000 miles?
Old Nov 16, 2008 | 06:12 PM
jalva_1's Avatar
I heard that it isn't a good idea to change the transmisson fluid at high mileage if it hasn't been serviced at regular intervals. Is this true?
Old Nov 16, 2008 | 06:43 PM
94toy4x4fever's Avatar
No, you need to change that fluid out! When was the last time it was changed? My father owns a transmission shop and I worked there for about 6 years and he always told me that a auto trannys fluid should be changed every 30,000 miles!
Old Nov 16, 2008 | 07:08 PM
84RNR's Avatar
I think that's only if the fluid is very dark and burnt smelling. If it doesn't look too bad, go get a BG Transmission Flush and you'll be good to go. A simple drain and refill gets less than half the old fluid out so you need the flush.
Old Nov 16, 2008 | 07:17 PM
eightnine's Avatar
My auto tranny had 220,000 kilometers before i changed the fluid (1st time ever in 19 years) and the tranny still works flawlessly. That isnt going to stop me from doing a 5 speed swap though.
Old Nov 16, 2008 | 07:28 PM
olharleyman's Avatar
The flush CAN , not will cause the seals to go out because of the renewed fluid pressure not to say it will or will not work just saying that's what I know about flushing auto tranny's after about 50,000 miles with out a flush in that time/mileage
Old Nov 16, 2008 | 07:29 PM
jalva_1's Avatar
A flush is what she gets then.
smthwsn357
May 1, 2024 07:28 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
mskalmus
May 28, 2017 07:51 AM
Liadrin
Sep 1, 2015 06:44 AM
Poncho0206
Jul 10, 2015 06:21 PM
