Toyota Maintenace Search Engine, Online FSM Manuals and Hunter Balancers
Originally Posted by atl-evo
I agree. Is there somewhere I can go and just pay the $10 for the entire d/l? I dont have time to sit in front of the comp and d/l one page at a time.
Thanks,
Thanks,
Hello from a newby
.... I read this thread and thought I'd share a tip to make the downloading faster. Describing it will sound a lot more complicated than actually putting it to practice. It works with WinXP and Internet Explorer (I have no idea if it works for other OS's or browsers???), and it saved me a ˟˟˟˟˟load of time over the open/save/close routine of trying to save each and every file. Here's the deal: IE stores a copy of every picture and document you open with your browser in your "Temporary Internet Files" folder(s) with the file's original extension. So all you need to do is delete all of the files (actually just the PDF's) from your "Temporary Internet Files" folder just before or after you log on to the Toyota Techinfo Site, and from then on each file you open/close will automatically be stored in the Temp Files folder as PDF's. The original document names aren't always stored, but you can rename later at your leasure. I found it best to create folders of each section and sub-section of the manual so that I could move (not copy) the PDF's from the Temp Files folder to the appropriate Section folder as each section completed. To make moving easier, the files in your Temp Files folder can be sorted by extension so that you're only selecting and moving the PDF's. Then start on the next section on the Toyota Techinfo Site. Repeat until you get everything. It took me around an hour to get everything using this method. Disclaimer: This post assumes that the user knows their way around the WinXP file system and where your user temp files are stored (usually C:\Documents and Settings\[user]\Local Settings\Temporary Internet Files\*.*) and how to safely search, move and delete files. Like I said, it sounds more complcated than it really is, but it will save time in the long run.
Anyone with Windows XP SP2 still having problems downloading the docs?
If so, it probably has to do with the internet connection firewall & popup blocker. Is Toyota aware of this and do they offer any refund or alternate method of downloading docs?
#25
Has anyone managed this downloading with SP2 installed? If so, how did you do it? I'm planning on doing it soon, but I'll spring for the actual manual if this isn't going to work for me with SP2.
Regards,
Joel
Regards,
Joel
#27
Originally Posted by waskillywabbit
I don't think you understand just how MANY pages the FSM contains....you would burn up a laminating machine...
When my wife saw my FSM when I took it out of the box she said "why did you buy a dictionary?"
About 3-4 inches thick...
congratulations!
-f-
#29
Originally Posted by oilguy3
instead of downloading and printing has anyone tried to download it and burn to cd? Make your own digital copy and save a tree.
#30
I have both...but the tree is easier to work w/ when your hands are greasy and you are under the rig ya tree hugger.
#31
My local Toyota dealership gave me a number (800-622-2033) to order the manual for my '97 T100. Cost was $118.74 plus shipping. Have any of you found a hard copy price better than this?
That online download is looking better and better; but I have Windows 2000 and a direct dial up connection; so don't particularly want to do it from this machine.
#32
Yes, last night I downloaded bunches of stuff with SP2 installed. All I did was turn off the pop-up blocker. As I couldn't find where my temporary internet files were I just saved each .pdf downloaded and gave it a name. Took maybe four hours to download most all I could ever want.
Oh yes, the machine I used was a WinXp machine with a cable modem (post prior to this one mentioned my machine had Windows 2000 and a direct dial-up)
#34
The link to the Haweka/Hunter locator page is not valid. Try this address: www.gsp9700.com
#35
Originally Posted by Lowlead
Hello from a newby
#37
Originally Posted by Rishi
I tried your idea, but it does not work at this particular web site. Reason: many of the PDF documents have the same name and so they just overwrite the earlier downloads. I discovered it the hard way! I finally had to give a name to each document during download, or put them in different directories. After 10hrs I managed to get all ! Now that's worth $2500.
I first tried just renaming the files 1, 2, 3, etc thinking I could save time, but what a PITA that was renaming them all after the fact. :pat:
Finally got some efficiency by copying root name of the file for each section, and pasting in as the new name and adding/modifying the extension.
#38
I got all the stuff for my 85 4Runner in about 15 seconds...I bought a complete FSM on Ebay. Do yourself a favor and save the time and just get an FSM. I then found a electronic copy elsewhere for
FREE.
So now I have both and I have a lot less time in it than 10 hours. I can print out what I want or heck I can photocopy straight out of the FSM. If you are going to work on your rig regularly, stop being a tightwad and just get a OEM FSM.
FREE.
#40
FSM shows you how to assemble/disassemble, maintenance, etc. OEM dealer/parts dealer have the part numbers, but you can get the names of things by the diagrams and get a good picture of what you need so you can intelligently ask the dealer FOR the part number or your local auto parts store. Heck, I can photocopy the diagram and take it with me to show them and make sure I get the right stuff.
