TJM Front Bumper
Lmao they have seen better days. perfect example of not rotating them and maintaining the air pressure on them
haha i think they only have 27k miles on them? somewhere around there. should've lasted me like 40k
33x10.50 BFG all - terrains are coming to me though
haha i think they only have 27k miles on them? somewhere around there. should've lasted me like 40k33x10.50 BFG all - terrains are coming to me though
o wait mike i see a little crack in the left blinker!!! you got ripped off now lmao take it back and i will buy it
dude line X that thing! would look beefy as hell!
im thinking of a addicted offroad winch bumper or a warn? i cant make up my mind and i dont even have money to buy one yet lol
dude line X that thing! would look beefy as hell! im thinking of a addicted offroad winch bumper or a warn? i cant make up my mind and i dont even have money to buy one yet lol
Warn has a pick up rear bumper too
might look good with a warn front/rear combo. that'd be pretty sick. I found these on the net, they're exactly what I want welded on.
http://atozfabrication.com/store/pro...tseller=Y&js=n
might look good with a warn front/rear combo. that'd be pretty sick. I found these on the net, they're exactly what I want welded on.http://atozfabrication.com/store/pro...tseller=Y&js=n
http://cgi.ebay.com/ebaymotors/Pair-...item3ef72116d3
#26
#27
oh sweet. I'll probably go with the smittybuilt 8k lb one. its only 300 bucks. im gonna mount my Cb radio antenna to the front later today. Im also gonna go with Kragen 8" lights, 2 of them. D shackle mounts, and maybe 2 4" fog lights for a little more light. then Im gonna Linex it and be done with the front bumper haha
#29
1st Modifcation:
Here's some pictures, rewired the CB radio to the front.
also a perfect sand dune flag... whatcha think?
pulled it off my little sister's bike...
#31
on the plate? you mean near the fender? i'd have to drill a hole... lemme get used to the bumper first. hahaha
and nope. I ordered tires, and bought the bumper instead. I'll get around to it. Like I said, I compulsively bought this bumper... lmao saw it, called, bought it.
#33
amazon.com!
haha its stainless steel too. my last one rusted.
http://www.amazon.com/Firestik-Heavy...7289005&sr=8-1
#34
amazon.com!
thanks
#35
Sweet
dont be disappointed if you cant bend the spring by hand. put it on, mount your antenna and test the flex. you'll be able to bend it then. trust me.
I added a hi-lift and tube mount to my bumper today
pictures later, im at work for another 30 minutes. haha. It looks damn good, just need to move it around a bit, its mounted over my hood, looks kinda goofy there.
dont be disappointed if you cant bend the spring by hand. put it on, mount your antenna and test the flex. you'll be able to bend it then. trust me.I added a hi-lift and tube mount to my bumper today
#36
2nd Modification:
48" Hi Jack lift w/ Tube mount. Whatcha think? got it from Central 4wd. Since I canceled my 2" body lift. They gave me my $100 deposit back in store credit.
#37
Bumper looks good....two things, can you see with that antenna? Do you detach it while driving in the city? I'd move it somewhere to the pass side, way off to the side. The jack will get jacked if you drive with it there and not drill the studs and put pad locks through em. Don't worry bout the lenses cracking, those turn sigs suck big time. I just welded mine shut as they always leaked, corroded and shorted out (even after I tried sealing). I'd give you the lenses for free but I threw them in the trash. It looks good but its just gonna look way cluttered with all that stuff on there.
#38
I daily drive with the antenna... its half an inch thick, pretty sure it wont cause "visual" problems. and I dont drive with the Hi jack on... lol I just put it on for pictoral preference to show how it mounts
Winch will be next, and then 2 lights
#39
I was going to have my friend weld on shackle mounts on mine too but he said that metal is not thick enough and if we did that then i tried to use them they would rip the bumper. so i left them where they are, on the frame below the bumper, stock towing points on a 3rd gen i think.
