Which of these wheels
Old Oct 28, 2006 | 08:45 AM
CJM's Avatar
CJM
Originally Posted by AH64ID
Despite the nascar thing... I will disagree with that. they made a HUGE difference on the braking power of my dads 97 K2500 burb. They stay much cooler, and cooler brakes are stronger brakes.
I had a set on my camry, they made no difference between them and a set of brembo blanks with a good set of perfromance pads. Sure they dissapate heat faster, but god help you if they warp you might as well throw them out. If you went from oem chevy parts, of course there will be a difference.
Old Oct 28, 2006 | 09:29 AM
04 Rocko Taco's Avatar
Cross drilled and or slotted rotors can work better in high temp applications to dissipate heat, I LOVE thesr rotors, buts its mostly a cosmetic thing, rotors like these were designed for temperatures that our rotor (hope and pray) will never ever ever see.
Old Oct 28, 2006 | 05:43 PM
AH64ID's Avatar
Yeah... its the hunting rig and towing a 4horse trailer down a steep gravel grade.. brakes get hot.. the OEM chevy ones are actually a great brake, only upgraded for extra heat dissipation and the added braking power.
Old Oct 30, 2006 | 07:12 AM
snapankle's Avatar
but, as far as the improper cuts that actually connect with the drilled holes (on one side) - is this a problem as far as safety?
kouki420
Sep 2, 2015 11:42 AM
NCRidgeRunner
Aug 13, 2015 04:11 AM
Up&Down
Aug 5, 2015 06:20 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
skoti89
Jul 6, 2015 07:45 PM
