Starting problems when HOT and COLD
Old Aug 15, 2005 | 08:41 PM
fo_runner's Avatar
Either when my engine is cold, or hot, at first start-up, i would have to crank the engine twice to get it started. But once the engine is started, my idle speed would go above 1000 RPM; even when the engine is heated to operating temperatures. When i adjust my idle back to reconmended specs; after a while, it would go back up again. Creepy
Old Aug 15, 2005 | 10:42 PM
bike4miles's Avatar
I would run some gas cleaner to start. It fixed mine. Some times the cold start injector gets cloged.
Old Aug 16, 2005 | 09:26 AM
fo_runner's Avatar
I already put in Redline's fuel system cleaner at my last oil change. This problem is starting to creep me out.
Old Aug 16, 2005 | 12:28 PM
nieking's Avatar
I'm not sure if this will help, but I've got an 01' Taco with a 3.4L and it began to idle rough a few months ago. As I attempted to troubleshoot it over several weeks, the problem progressed to stalling out while trying to seek idle after warmup. Finally, I found that Toyotas have problems with their Idle Air Control Valves (IAC) which tend to gum-up over time preventing it (the valve) from operating properly. The gum-up is a byproduct of the EGR system and/or cheap gas.
The solution is to remove the throttle body (4 bolts, 3 hoses & throttle cable), and on the underneith side held on by two bolts is the IAC. simply remove it and you'll see the black gummy carbon deposits. Soak it down with a good cleaner (I used DeepCreep by Seafoam) and scrub it with an old toothbrush. This completely fixed my idle problem.
Good luck.
Team420
Jan 12, 2021 04:57 PM
Regency
20
Jan 3, 2020 07:43 PM
the1998sr5
Oct 19, 2016 12:48 PM
Cesarl74
Apr 23, 2016 06:07 PM
Jnkml
Jul 6, 2015 01:20 PM
