sagging Bilstein shock
Old May 27, 2009 | 12:16 PM
buhrito's Avatar
'98 Tacoma Reg cab
2.7L, 5spd, 4wd
I have Bilstein shocks (10" 5150 Series with 255/70 valving). They came on the truck and I don't know much about them.
The rear left shock always sags a little. At best, about an inch and at worst, maybe 2-1/2 inches, or so.
Anyone know if these can be adjusted in some way?
thanks
Old May 27, 2009 | 12:25 PM
4Crawler's Avatar
Shocks like that should have no affect on the ride height at rest, they only control the damping of up and down motion. If one corner is sagging, likely a problem with the spring or other suspension part on that corner. I think there was some sort of factory recall or TSB on the earlier Tacoma rear springs that you might check into.
Old May 27, 2009 | 12:51 PM
buhrito's Avatar
ah yes, that makes sense. I added leaf springs to an S-10 I once had so, hopefully I'll be able to do this one too.
Any recommendations on what to order? I see some companies state that their springs provide "near factory ride height" or something along those lines. Since this Yota has 10" shocks, I'm not sure if that's what I would want.
ladybugRC
458
Aug 21, 2020 10:41 AM
ZGjethro
Jun 7, 2017 11:04 PM
dirk89
Oct 1, 2015 05:15 PM
ktm192k
Oct 1, 2015 08:47 AM
toyotasaurus
Sep 24, 2015 03:30 PM
