Restoring wheels
Old Sep 27, 2010 | 02:15 PM
Swimmerboy2112's Avatar
Restoring wheels
When i bought a set of tires they came with a good set of wheels, only thing is the wheels' clearcoat is starting to spider and crack. How can i fix this? I was going to sand them down but i dont want to leave tons of scratches in my wheels. What do you guys suggest?
Cracking on the bottom part.
Old Sep 27, 2010 | 03:24 PM
warpigg's Avatar
you can try wet sanding with some like 800 and above sand paper, then just spray more clear coat on them.
Old Sep 27, 2010 | 03:26 PM
HighLux's Avatar
Try polishing it out? Those are aluminum right?
Old Sep 27, 2010 | 05:23 PM
See i'm afraid that the 800 grit is gonna scratch the hell outta them.
What would i polish it out with? And i'm not sure it'd work. But yes they are aluminum.
Old Sep 27, 2010 | 05:29 PM
HighLux's Avatar
those mothers powerball jobs work awesome. dont last forever....but work great. Then get some aluminum polish....mothers makes some too
Old Sep 27, 2010 | 05:33 PM
warpigg's Avatar
notice i said 800 and above, and when you wet sand theres less friction so there are less scratchs. try 2000 grit and wet sand it, then im sure that wont scratch them at all.
Old Sep 27, 2010 | 05:36 PM
HighLux's Avatar
A non ferrous metal should be polished...not sanded to restore its finish.
Old Sep 27, 2010 | 05:40 PM
warpigg's Avatar
ya but your not sanding the metal your sanding the clear coat, otherwise i would use mothers polish.
Old Sep 27, 2010 | 05:44 PM
Yeah i was going to use polish but thought about it and realized i wouldnt be polishing metal i'd be polishing clear coat. That's why i posted up here.
Old Sep 27, 2010 | 05:50 PM
HighLux's Avatar
Sand away then...
Old Sep 27, 2010 | 06:13 PM
Sand away then...
I guess, i'm just scared to start sanding away my wheels
Old Sep 27, 2010 | 06:23 PM
HighLux's Avatar
That is why you should listen to me and polish them with 3 stages of compound.
Old Sep 27, 2010 | 06:44 PM
2DoorRunner's Avatar
Yeah highlux is right. some decently "rough" polishing/buffing compound should get through the clear coat, then hit them with some aluminum polish if you want it to shine.
Old Sep 27, 2010 | 07:17 PM
Alright i guess i can give that a try. You guys suggest Mothers stuff?
Old Sep 27, 2010 | 07:21 PM
Mothers is good and has a good rep, but IMO for offroad wheels get whatever is cheap, and leave the expensive stuff for the show cars
Old Sep 27, 2010 | 07:29 PM
Yeah true good call. So any buffing wax will work?
Old Sep 27, 2010 | 08:00 PM
You can get some liquid buffin compound in bottles, i dont knkow how they rate the grit, so you will have to do a little research, but my guess is that you should get close to the roughest one you can.
Im no detailer so i can only tell about the materials i have used, but that liquid compound should do the trick.
Old Sep 27, 2010 | 08:04 PM
This is the stuff i am thinking of.
http://www.ehow.com/how_2141516_buff...-compound.html
It should be pretty cheap for a small bottle. Let me know if it works!
But keep in mind i only THINK it will work, i dont know for sure
Oh and it will coat the wheels in black junk, it happens when polishing aluminum, a rag will wipe it off.
Hope it works out for ya!
Old Sep 27, 2010 | 08:10 PM
Why didnt any of us think of this lol
http://www.google.com/#sclient=psy&h...36e88d83826287
Almost every link on the first page says to use some sort of paint stripper. You can decide what will work better.
Old Sep 28, 2010 | 03:39 AM
I guess i'll try the rubbing compound and buffing first then if that doesn't work i'll try the paint stripper. Thanks 2DoorRunner!
