rear main seal
Old Feb 21, 2008 | 07:33 PM
87toy.'s Avatar
rear main seal
so im going to replace my clutch, should i replace my rear main seal? ive been told, that if its not leaking not to cause they dont need it unless they leak? id assume i should, but im not sure.
Thanks Joe
Old Feb 21, 2008 | 07:35 PM
jason191918's Avatar
For what it's worth you may as well. Hate to spend next weekend replacing a cheap seal cuz you were lazy this weekend. Make Sense?
Old Feb 21, 2008 | 07:36 PM
drew303's Avatar
Go ahead and replace it if you got the clutch out. You'll also need to replace the rear oil retainer seal as well.
It's not hard to do when the tranny is out.
Old Feb 21, 2008 | 08:00 PM
87toy.'s Avatar
what is a rear oil retainer seal?
Old Feb 22, 2008 | 07:30 PM
87toy.'s Avatar
..... trick question?
Old Feb 22, 2008 | 07:32 PM
drew303's Avatar
No not a trick question
The rear main seal is IN the Oil Retainer. It's a aluminum cover that goes on the back of the motor (like the front cover) but it surrounds the rear crank output and the rear main seal is actually pressed into it. Then the retainer is bolted to the block. Inbetween the retainer and the block you put a seal =P
It's just a gasket, use RTV w/ the gasket.
Old Feb 22, 2008 | 07:51 PM
87toy.'s Avatar
ok. so oil change too.
Old Feb 22, 2008 | 07:59 PM
drew303's Avatar
Yea! =p
Drain the oil first to btw.
Old Feb 22, 2008 | 11:32 PM
87toy.'s Avatar
arg, says i need to drop the oil pan to remove the retainer....
Old Feb 23, 2008 | 06:22 PM
84sr5yoty's Avatar
Yea! =p
You don't need to drain the motor oil. I replaced both seals without any oil leaking out.
Old Feb 24, 2008 | 07:06 PM
87toy.'s Avatar
ill find out when i do it
88sasturbotoy
Jan 30, 2026 01:57 PM
jerusry
Oct 19, 2015 05:28 PM
Iceman4193
Jul 15, 2015 04:48 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
toyoda8488
Jul 5, 2015 10:18 PM
