Rear end break in?
Old Jun 20, 2006 | 06:49 AM
boraxman's Avatar
Rear end break in?
How soon after installing a new ARB with fresh oil should it be be changed? Does it need to aside from regular maintenance? Thanks.
Old Jun 20, 2006 | 06:57 AM
AH64ID's Avatar
Did you change the gears too?
Old Jun 20, 2006 | 07:06 AM
snap-on's Avatar
more to the point, did you use new gears or some used ones? (it makes a diffrence)
Old Jun 20, 2006 | 07:10 AM
boraxman's Avatar
No just the ARB and new carrier bearings. Same original gears.
Old Jun 20, 2006 | 07:27 AM
AH64ID's Avatar
Go 500 miles, driving normal... drain and fill with synthetic..
Old Jun 20, 2006 | 12:12 PM
tc's Avatar
tc
Which is the same as for new gears, isn't it?
For the benefit of those who find this later by searching, there will be quite a bit of black stuff when you drain the diff. This is a coating applied to the gears that wears off and not cause for concern.
Old Jun 20, 2006 | 01:01 PM
AH64ID's Avatar
Yes, but with new gears you want to avoid wheeling, towing, racing, full throttle driving for those 500 miles. As well as drive the inital 25, let it cool, then dont go more than about 100 with out letting it cool....
I also reccomend getting a second mag plug from toyota to go in the fill plug.
the1998sr5
15
Jul 14, 2020 08:35 PM
Daneums
Aug 20, 2015 05:36 AM
hangtown88toy
Jul 10, 2015 02:33 PM
akaphilly
Jul 9, 2015 02:18 PM
toyoda8488
Jul 5, 2015 10:18 PM
