R4/split second tuning suggs
Old May 5, 2009 | 05:23 PM
94upercharged's Avatar
What I have is a 1994 2wd toy and I have built a low compression engine with CP forged pistons with a comp ratio of 7.9:1 and a turbo/blower specific cam it also has a Camden supercharger 10 psi kit and then the head has been reworked in the bowl area and has larger valves and is also port matched then I put a MSD 6BTM box on it and finally I bought the Split second FTC setup which came with 420 cc injectors and an upgraded fuel pump and also a conversion from an AFM to a MAP sensor so my main question is has anyone played with the software before and if so do you have any tuning tips.
ladybugRC
458
Aug 21, 2020 10:41 AM
MadMax48
Mar 3, 2020 10:33 AM
urabus
Nov 10, 2015 07:38 PM
the_supernerd
Oct 1, 2015 09:20 PM
