Power Steering
Old Sep 3, 2007 | 09:57 AM
rk2runner's Avatar
Power Steering
Hello all,
I have a 1990 4Runner V6 and I am wondering if anyone can tell me what the 2 rubber hoses (connected through a "y" fitting) are for going to the power steering pump?
The rubber hoses do not appear to be pressure or return lines nor do they appear to be carring any fluid. One of the rubber lines has been broken for a while and I want to reconnect it but I dont know where it goes. The other line looks like it is connected to a square valve or a vacuum source of some sort but I cant figure out why the pump would need a vacuum source.
Thanks
Old Sep 3, 2007 | 11:07 AM
86tuning's Avatar
Those are the p/s idle up vacuum hoses to keep the engine from stalling.
The thing they're attached to is a pressure switch. When the p/s has high pressure, it allows a bit more air to bypass the throttle and bump the idle speed up slightly.
Almost all of the 2000 and older Toyotas have them. Cars, trucks, vans, etc. Recently they've switched to an electrical switch on the cars with ETCS (electric throttle control system).
Fix the vacuum hoses. One runs to the intake manifold, the other one runs to the intake tube before the throttle.
Old Sep 3, 2007 | 12:30 PM
rk2runner's Avatar
Hi Brian,
Thanks for your response. I went and looked under the hood and I did not see any broke or missing hoses at or near the throttle body. I got a mirror and looked along the firewall/back of engine and did not see anything disconnected. The broken hose from the p/s pump is near the 4 vacuum switches on the rt front fenderwell. I looked all around this area too and I did not see any place to attach the broken p/s hose. This mystery hose has to attach somewhere?
I am also getting an "overdrive off" light illuminating on the dash. Do you know what could be causing this?
Zpd426
Jan 2, 2016 01:15 PM
delmert
Sep 30, 2015 04:34 PM
Up&Down
Aug 11, 2015 10:04 AM
toyoterferdayz
Diesel Swaps
Jul 27, 2015 05:25 PM
gmonnie123
Jul 26, 2015 02:44 PM
