New engine. Need help
Old Oct 30, 2016 | 11:25 AM
sandman666's Avatar
Question for the mechanics.
I have freshly rebuilt 22r that has a rv cam,Weber 32/36 carb ,complete desmog, timing set at 0 with vacuum lines plugged. Runs like there is a miss. All plugs are firing. I can't seem to get it to run smooth. Any suggestions?
Old Oct 30, 2016 | 12:30 PM
wyoming9's Avatar
Red face
Check the compression maybe one cylinder the rings have not seated
Bad lobe on the Cam
What head work was done ?/
One of the valves did not seat or bad valve seat
one injector not firing .
It might be as simple as a plug wire on wrong bad plug wire
Quite a few things might cause a miss
Old Oct 30, 2016 | 12:37 PM
sandman666's Avatar
New cam.
No injectors
plug wires and plugs firing
no head work done
motir run smooth before rebuild just spun a bearing
Old Oct 30, 2016 | 01:26 PM
millball's Avatar
Valve lash correct??
