Need replacement aisin manual locking hub part.
So just the other day while playing at the beach doing hill climbs i managed to snap my front right axle cv shaft. It broke right before the spline so that was good but when it broke some how the outer hub cap ( the part you turn ) was destroyed and now needs replacing. Pieces of the part your turn actually broke off and you cant even turn it now. So I only really need that cap piece not the whole hub and I'm not looking to spend too much for it. All i have found for replacing it was to buy a whole new set of locking hubs which is not to cheap. I checked my local junk yard but no luck. If you have any ideas that would be great. Thanks, Neil.
FYI that picture is off Google I'm using it to show whats broke.
Wabbit? Classifieds? Craigslist?
I ended up going through Craigslist when I needed parts for my front hubs I found a guy that had a pair for $60-70 I can't remember exactly. Also some and I say some not knowing what will swap, Aisin hub parts have been rumored to be interchangable. I guess you could pull your good side apart (read about it first don't lose the little ball bearing). Measure the dial or just take it with you and go to the junk yard. Isuzu Toyota proabably Nissan, all used Aisin hubs for the manual ones. Pull one apart in the yard if it works your good to go. Also just learn to search type specific questions and see what you get
Jun 1, 2021 01:51 PM
