manual locking hubs differences
Old Jun 29, 2009 | 05:35 PM
hauckster's Avatar
So i have 3 sets of manual locking hubs from 3 different trucks laying around so i figured that i would clean them up and put this thread together about the differences between IFS and solid axle locking hubs. Most parts of there hubs are interchangeable as we all know by now but i have yet to see a thread on the differences so here it goes.
I have hubs off of an 87 4runner, 87 pickup and, an 81 reg cab
Be forgiving some photos are a bit blurry because i am no photographer
IFS is on the left and Solid Axle is on the right
Both hub bodies are the same as you can tell there is no difference other than the wear and tear on them for being over 20 years old each
All the internals laid out
IFS hubs
Solid Axle hubs
Dials, the dials are interchangeable the only differences are the part number on the back 7C is IFS and 1B? is Solid axle
IFS is flat and the Solid Axle nobs are raise out for ease of turning
The IFS Free Wheel Hub Ring has little round holes to hold grease where as the Solid axle ones do not
The Clutch form the IFS hub is in front of the Solid Axle hub as you can see the internal splines are offset but i do believe that this would not matter if swapped to an IFS hub
The Inner Hub of the IFS has only a 27 spline count where as the Solid Axle Inner Hub has a 30 spline count there for bigger hole
The Inner Hub of an IFS has an inset ring pattern on the top of the hub where as the Solid Axle does not it just tapers off towards the splines
The solid Axle Inner Hub is slightly taller than the IFS hub due to the added length of the component
Hope this helps everyone
Old Jun 29, 2009 | 05:58 PM
RobD's Avatar
Good points.
As for input on your photography, look for a setting on your camera that allows for macro photography. If you let me know what camera you have, I can probably tell you how to get those close-ups in focus.
glowz825
Jan 25, 2022 09:28 AM
oldirtydirt
Feb 23, 2020 09:30 AM
deepmarsh
Aug 6, 2015 03:44 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
ItsJustD
Jul 7, 2015 07:49 AM
