maintaining high RPMs with 22R-E
Is there anything wrong with maintaining over 5000 RPM for extended periods?
During a recent trip from Allenspark to Glenwood Springs, I maintained about 5000-5500 in 3rd around the Avon/Vail area on I-70 for about 20 mins.
Got it up to 106 in 5th
just wondering if I should have concerns about revving this high for so long. valves seem to get floaty above 5300.
I normally shift around 2400-3000.
When pulling grades, I maintain 3000-4500 in 3rd, such as when driving up Highway 7 to get to Bunce.
James
I wouldn't recommend it. The valve train is weak in these motors. I know first hand with my FWD Prue-runner. I used beat the living piss out of it. I have personally took it to 7500 many times. Why? Because I did not care and I was bored. Well the head gasket went and I pulled the head and sent it out to the machine shop. The valve seats were hammered so they had to install new valve seat and redo the valves.
James
James
any stock Toyota truck motor that has factory Efi will never see above 6,250 RPM. they have rev-limiter that wont allow it.
as for the op, as long as its not a high mileage motor you will be fine.
My understanding is that a 22RE will take that all day, but a Jeep 4 cyl would self-destruct in short order. 22REs are tough, so you'll be fine I think. Just make sure you have good oil in there. Toyotas seem picky about clean oil.
yeah i once towed a trailer with 3 motorcycles and my canopy on full of tons of campnig geer, maintaining 75-80 in 4th gear at around 5000 RPM's in my 22re pickup and had no problem towing for a 3 hour period.
coffey50
Jul 28, 2015 10:55 AM
