Les Schwab wont touch my brakes
Subscribe
Feb 15, 2014 | 12:56 PM
Les Schwab won't fix my brakes they say my truck is not safe and they don't want the liability as a corporation to fix my brakes. They had me walk under my truck and showed me every flaw that freaked them out. They don't like that she has been bobbed, they don't like her welds, they don't like her wheel bearings. You think she's not safe now how about when I can't stop cause I have no brakes.
They funny part is: ( Les Schwab) "We are used to working on trucks like yours" (Me) Are you sure? (Schwab) "positive" Until they went to check her brakes...the big "OMG"
They think I have a leaky wheel Cylinder. But they won't fix it....more stress, just what I !@#$ needed. So I guess its time to learn to fix my own breaks, I wonder how hard it is to change out a wheel cylinder? Good thing I bought a bigger Jack!!!!
(Don't mean to carry on but they really ticked me off)
Reply 0
Feb 15, 2014 | 01:06 PM
Um....why wouldn't you fix your own brakes? Didn't you build this rig?
Brakes are like basic fundamental mechanicinicin...
Reply 0
Feb 15, 2014 | 01:29 PM
No I didn't But let me tell you I wish everyday that I had.
I bought it(not knowing) thinking everything was fine. But I will certainly build the next one!!! I hate brakes, but if I havvvvve to, I guess Ill do it. I just don't like all the springs and crap!!! And I am running short on time due to reg and smog stuff. Just thought it would be nice to have a pro do it they have all the stuff on hand. Basic mechanik stuff yes, but I hate it......
Reply 0
Feb 15, 2014 | 01:42 PM
Brakes are like the easiest thing to do besides changing your own oil. Put on your big boy britches and get er done.
Reply 0
Feb 15, 2014 | 02:30 PM
Sometimes letting folks know where you are helps. There may be someone nearby that is willing to lend a hand and teach you some things.
Reply 0
Feb 15, 2014 | 05:31 PM
Big Boy Pants....:)
I don't wear big boy pants....I wear big girl pants....LOLOLOLOL But I will definitely put my big girl pants on and break out the big jack and get er done My dad and brothers gave up a long time ago trying to keep me out of the garage and out from under the hood. I love mechanicin, just don't like brakes.
Reply 0
Feb 15, 2014 | 05:34 PM
RokBlok
I have enlisted help, I am located in northern most Part of CA.
Reply 0
Feb 15, 2014 | 06:15 PM
Reply 0
Feb 16, 2014 | 02:41 AM
We really need to see just how bad this truck is.
In this day and age (bounty on lawyers anyone) with no one taking any responsibility for doing anything but a select few of us.
I can understand Them not working on your Truck I think a lot had to do with your gender but so very hard to prove.
Yes I gotta admit as well I hate working on brakes as well not that I can`t when it needs done
Reply 0
Feb 16, 2014 | 07:58 AM
Gender Issue
When it comes to my gender I have been dealing with boys(not men) getting mad or not wanting to help for as long as I have been working on cars. My brothers have had to deal with a few of them face to face a couple of times. I think Les Schwab boys thought it was my boyfriends truck, when they found it was mine and I was rebuilding her the refused to help. But proving that this was their motivation, near impossible. I had a bad wheel bearing that needed fixing...they fixed it only because I made them aware that me leaving their shop with them having the knowledge that my tire was about to fall off could possibly lead to a major liability issue for them. They agreed and fixed it!! And I stand corrected my tires are 35s not 30s. But it doesn't matter I will fix my brakes it has to be easier than the wiring harness...right?
If I need further help I will come back here to Yotatech where I have received more help and support than anywhere else
PS the videos are awesome thank you
Reply 0
Feb 16, 2014 | 08:01 AM
How bad this truck is....I will send picks as to why they wouldn't fix the wheel cylinders, and wouldn't install an ebrake cable. I have to figure out how long it needs to be for the 80 body I don't think it should be tough to install.
Reply 0
Feb 16, 2014 | 11:22 AM
First Drum brake work...
Struggled a little with the adjuster but didn't quit till I figured it out, yep I locked it up really tight..lol. Found the release tab and turned it back the other way..yay it came right off. Didn't find it leaky but I cant ignore the gunk on the rim. I am currently trying to find a source for Aisin cylinders apparently its a 7/8 bore. Can I put a 1" bore or should I stick with what is there? Its pretty rusty but when I pulled the hub off it was drys, no fluid until I pulled the rubber caps back, seemed like the fluid had pretty good pressure too.
Reply 0
Feb 16, 2014 | 11:32 AM
can't delete attachments?????
I was going to send pics but Yotatech said I was over my quota for attachments, does anyone know how I can go in and delete some of the old pics? I tried to access attachments in user CP but it comes up with server error.
Reply 0
Feb 17, 2014 | 12:37 PM
Brakes then Leaf springs...hmmmm? Lets see I need: 4 leaf springs, A backhoe, a length of chain, then I can get them changed.
Reply 0
Feb 17, 2014 | 01:16 PM
Shows your thinking just don`t use cinder blocks to support your truck.
Reply 0
Feb 17, 2014 | 04:53 PM
Wyoming9
How about stumps??LOLOLOL
Reply 0
Feb 19, 2014 | 03:36 PM
Found a guy that knows a guy
Probably wont need those stumps after all I went to a different tire shop to double check the wheel bearing job that Les Schwab did(thought I felt the wobble) and he knows a guy that will be able to help out with the leaf springs
Reply 0
Feb 19, 2014 | 04:40 PM
I need to see this specimen. Let's see some pictures.
Reply 0
Feb 20, 2014 | 08:13 AM
I have an album on profile
Here is a pic...I need to take pics of underneath but haven't done it yet brakes first
Reply 0
