Ignition switch/ interlock issue
Old Mar 2, 2007 | 05:18 PM
O26Rcr's Avatar
Hey guys, I've got a '95 4X4 Hi-Lux pickup with an auto transmission. I got in it to go to the gym this evening, and the key seemed a little sticky going into the cylinder. Once all the way in, it does NOT want to turn at all. It appears the flap that turns the key sense switch on and off is at a strange angle, but the key will still insert all the way once you get it past that section of the cylinder. Any suggestions other than a quarter stick, and go buy a new truck? Thanks.
BTW great forum, I swapped in a new 3.0 last fall and you have a lot of very useful information here.
Old Mar 6, 2007 | 12:07 PM
Adam F's Avatar
A little messy, but spray some good penetrating lube like PB Blaster into the cylinder and let it sit, and work the key in and out for a bit.
Old Mar 6, 2007 | 01:04 PM
surf4runner's Avatar
still messy, but ive found graphite to be effective
Old Mar 28, 2007 | 10:23 PM
O26Rcr's Avatar
Thanks guys, actually tried tri-flo and it seems to be working fine now. To keep it from sticking again, I'm gonna sell the truck and pick up a spotless '97 Taco I found. =)
Old Mar 30, 2007 | 09:33 AM
spaceycayce's Avatar
Also could be a bad key, I had a worn out key get stuck in the ignition and was a real PITA to get it to work. Try to see if you can get a new key made from the Dealership, that may work too. I got it fixed for free they just gave me a new key and I was on my way.
80Truck
Oct 12, 2025 07:25 PM
Sleaker
Aug 26, 2020 06:03 AM
nickb3
Jul 21, 2015 10:00 AM
Hamonacracker
Jul 17, 2015 08:33 AM
94whiterunner
Jul 12, 2015 07:15 PM
