Hit a pole.. Now what?
Old Mar 3, 2014 | 05:18 PM
Roark's Avatar
Originally Posted by donomite49
fix it and drive on, it -is- a yota!!! good luck.
You can try to take the Yota out of the fight, but you can't take the fight out of the Yota!
She will live on.. In one way or another.
Old Mar 3, 2014 | 05:48 PM
Shoua's Avatar
Ouch.
Rock sliders would've helped in this situation.
Old Mar 3, 2014 | 05:57 PM
Roark's Avatar
Originally Posted by Shoua
Ouch. Rock sliders would've helped in this situation.
So would have snow tires and clearer roads.. And a warmer day.. And AWD.. And..and..and..
Roark's Avatar
I will definitely be considering armor for my truck whenever I get to moving the pieces. We shall see!
Thanks for the help guys.. Always appreciate a community effort.
Old Mar 4, 2014 | 07:36 AM
  #25
Roark's Avatar
Quick question.. I've been searching for trucks to swap bodies, and I've found both 2wd and 4wd trucks in adequate condition. Which should I gravitate towards? Will either be more or less work intensive to swap, and will either be more or less economically viable, in buying, parting, etc?
I'm just trying to get my other foot in the door, here.
Old Mar 4, 2014 | 09:04 AM
  #26
highonpottery's Avatar
either version should technically work - all the sheet metal is universal, it's the frames that are slightly different. body mounts should be in the same spots too. either way, moving a body mount isn't that hard if you have the tools.
rock sliders definitely would have helped in this situation. armor is cheap insurance for these types of things.
if this happened to my truck, i'd probably end up making a custom 4door like this guy did with a 4runner cab + the back of a truck cab:
custom double cab
sooo sick!
Old Mar 4, 2014 | 09:09 AM
  #27
dropzone's Avatar
Fossilized
Sometimes the transmission tunnel is a bit different (besides the obvious 2nd hole for t/c lever) between 2wd (lowe)and 4wd.
Old Mar 4, 2014 | 09:13 AM
  #28
Roark's Avatar
Oh, yeah, that's an easy one. Good point!
Old Mar 4, 2014 | 09:14 AM
  #29
Roark's Avatar
Originally Posted by highonpottery
either version should technically work - all the sheet metal is universal, it's the frames that are slightly different. body mounts should be in the same spots too. either way, moving a body mount isn't that hard if you have the tools. rock sliders definitely would have helped in this situation. armor is cheap insurance for these types of things. if this happened to my truck, i'd probably end up making a custom 4door like this guy did with a 4runner cab + the back of a truck cab: custom double cab sooo sick!
You've got me thinking, man!! Don't know if that's good or bad
Ive often considered making the truck into a double cab/shorter bed Frankenstein. Maybe this is my opportunity.
Old Mar 4, 2014 | 09:18 AM
  #30
cman1's Avatar
man,that sucks, its a hard call too. dont let anyone fool you, a cab swap is a whole lot of work even if everything goes well. id probably total it and find another one before theyre all gone!!!! seriously, that sucks and good luck with your decision.
live4soccer7
May 11, 2016 06:52 PM
Ditch Doc
Oct 27, 2015 03:20 PM
kbpickens
Oct 2, 2015 03:37 PM
creecher10
Sep 30, 2015 03:27 PM
83
Sep 27, 2015 04:13 PM
